double_gee
  • 63
Message 1 of 37
SuperHub 3 - dropouts and restarts
For the past month or so I get frequent dropouts in internet connectivity for a few minutes at a time. Some days it doesn’t happen at all, other days it can be a couple of times an hour for a few hours. I run in modem mode as I use an Amplifi HD And MeshPoints for my WLAN network and they remain up throughout and I can access local NAS whilst internet is down. Usually the hub has a white flashing light for a few minutes then a solid red light and logs don’t show errors at the time of the issue, though do show T3/no ranging response periodically and you can tell it rebooted by checking uptime on the info page. Also plenty Pre RS errors in logs. Anyone else experiencing similar? Is my hub on the way out?
double_gee
  • 63
Message 2 of 37
Re: SuperHub 3 - dropouts and restarts
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
363000000
6.1
38
256 qam
29
2
203000000
3
37
256 qam
9
3
211000000
3
37
256 qam
10
4
219000000
3
37
256 qam
11
5
227000000
2.9
37
256 qam
12
6
235000000
2.5
37
256 qam
13
7
243000000
2.2
37
256 qam
14
8
251000000
2.4
37
256 qam
15
9
259000000
3.5
37
256 qam
16
10
267000000
4.5
38
256 qam
17
11
275000000
4.9
38
256 qam
18
12
283000000
5.1
38
256 qam
19
13
291000000
5.4
38
256 qam
20
14
299000000
5.6
38
256 qam
21
15
307000000
5.5
38
256 qam
22
16
315000000
5.6
38
256 qam
23
17
323000000
5.8
38
256 qam
24
18
331000000
5.8
38
256 qam
25
19
339000000
6
38
256 qam
26
20
347000000
6
38
256 qam
27
21
355000000
6
38
256 qam
28
22
371000000
6
38
256 qam
30
23
379000000
5.5
38
256 qam
31
24
387000000
5.5
38
256 qam
32
double_gee
  • 63
Message 3 of 37
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
8
0
2
Locked
37.6
26
0
3
Locked
37.6
27
0
4
Locked
37.6
16
0
5
Locked
37.3
5
0
6
Locked
37.6
9
0
7
Locked
37.6
19
0
8
Locked
37.6
15
0
9
Locked
37.3
12
0
10
Locked
38.6
11
0
11
Locked
38.6
19
0
12
Locked
38.6
19
0
13
Locked
38.6
17
0
14
Locked
38.6
9
0
15
Locked
38.6
5
0
16
Locked
38.9
11
0
17
Locked
38.6
11
0
18
Locked
38.6
9
0
19
Locked
38.6
9
0
20
Locked
38.9
21
0
21
Locked
38.6
17
0
22
Locked
38.9
10
0
23
Locked
38.9
16
0
24
Locked
38.6
4
double_gee
  • 63
Message 4 of 37
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200014
48.3
5120
64 qam
3
2
32599949
48.3
5120
64 qam
5
3
39400019
47.8
5120
64 qam
4
4
53700000
49.8
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 37
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
double_gee
  • 63
Message 6 of 37
Time
Priority
Description
11/01/2021 10:44:42
notice
LAN login Success;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 21:14:17
critical
No Ranging Response received - T3 time-out;CM-MAC= ;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 10:28:11
notice
LAN login Success;CM-MAC= ;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 01:52:16
notice
SW download Successful - Via NMS
07/01/2021 01:51:28
critical
No Ranging Response received - T3 time-out;CM-MAC= ;CMTS-MAC= ;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 01:50:57
notice
SW Download INIT - Via NM
double_gee
  • 63
Message 7 of 37
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
sfd;kfoA,.iyewrkldJKDHSUB
SFID
896
Max Traffic Rate
575000000
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
895
Max Traffic Rate
38520000
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
BestEffor
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 37
Your Downstream Power Levels individually are all within spec but, the differential between the lowest at +2.2dBmV and the highest at +6.1dBmV is too great.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
363000000
6.1
38
256 qam
29
2
203000000
3
37
256 qam
9
3
211000000
3
37
256 qam
10
4
219000000
3
37
256 qam
11
5
227000000
2.9
37
256 qam
12
6
235000000
2.5
37
256 qam
13
7
243000000
2.2
37
256 qam
14
8
251000000
2.4
37
256 qam
15
9
259000000
3.5
37
256 qam
16
10
267000000
4.5
38
256 qam
17
11
275000000
4.9
38
256 qam
18
12
283000000
5.1
38
256 qam
19
13
291000000
5.4
38
256 qam
20
14
299000000
5.6
38
256 qam
21
15
307000000
5.5
38
256 qam
22
16
315000000
5.6
38
256 qam
23
17
323000000
5.8
38
256 qam
24
18
331000000
5.8
38
256 qam
25
19
339000000
6
38
256 qam
26
20
347000000
6
38
256 qam
27
21
355000000
6
38
256 qam
28
22
371000000
6
38
256 qam
30
23
379000000
5.5
38
256 qam
31
24
387000000
5.5
38
256 qam
32
double_gee
  • 63
Message 9 of 37
Waited until now with no response because I’m now on leave so avoiding impact to working from home. However after over an hour wait all they would do was get me to do a pinhole reset on the hub, put it back in modem mode and get me to restart my AmplifiHD router. Power level variance on downstream now 2.4 - 7.5 dBmV. Have no confidence this is fixed and will end up calling again with more problems. Offshore support are rubbish.
John_GS
  • 9.18K
  • 494
  • 831
Message 10 of 37
Hi @double_gee
Thanks for posting. My apologies for the delayed reply and indeed the broadband issues.
Everything looks fine from a system check today, all levels in specification.
Can you pop the hub in router mode for me so we can run further checks?
Kind regards,
John_GS
