Shanel
  • 9
Message 1 of 15
Super slow Internet speed
  • Hi  my Internet speed is super slow, running between 30 to 70 Mbps. I've reset the router and used the virgin app to reboot the router but still a poor speed. I have the 350 Mbps package.... ideas 💡 please
Anonymous
Not applicable
Message 2 of 15
Re: Super slow Internet speed
Wired or wireless?
Shanel
  • 9
Message 3 of 15
Both are slow WiFi and wired
I have the 3.0 hub
Anonymous
Not applicable
Message 4 of 15
I have the 3.0 hub
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
Shanel
  • 9
Message 5 of 15
Something like this??
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12027500003.540256 qam9
21387500004.540256 qam1
31467500004.840256 qam2
4154750000540256 qam3
51627500005.140256 qam4
61707500005.140256 qam5
71787500004.840256 qam6
81867500004.540256 qam7
9194750000440256 qam8
102107500003.440256 qam10
112187500002.940256 qam11
12226750000340256 qam12
13234750000340256 qam13
142427500003.240256 qam14
152507500003.740256 qam15
162587500003.740256 qam16
172667500003.940256 qam17
182747500003.240256 qam18
192827500003.240256 qam19
20290750000340256 qam20
212987500002.740256 qam21
223067500002.740256 qam22
233147500002.540256 qam23
243227500002.940256 qam24
1Locked40.9180
2Locked40.910851
3Locked40.35924
4Locked40.35111
5Locked40.3340
6Locked40.980
7Locked40.350
8Locked40.9110
9Locked40.9160
10Locked40.9440
11Locked40.3240
12Locked40.9100
13Locked40.3120
14Locked40.9170
15Locked40.9190
16Locked40.9130
17Locked40.950
18Locked40.300
19Locked40.9140
20Locked40.3130
21Locked40.3120
22Locked40.340
23Locked40.980
24Locked40.900
Shanel
  • 9
Message 6 of 15
15370004845.8512064 qam6
23939992245.8512064 qam8
34620001745.8512064 qam7
46030000745.8512064 qam5
3ATDMA0000
4ATDMA0000
Shanel
  • 9
Message 7 of 15
14/11/2020 21:54:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 21:53:51Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 21:14:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 21:10:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 21:05:35criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 8 of 15
@Shanel wrote:
Although most of the HUB stats look ok you appear to have a lot of errors in your network log within a short period of time.
The BQM I mentioned should show if you have an issue with your line.
Shanel
  • 9
Message 9 of 15
The speed has never been this slow, still running about 30Mbps and upload has dropped to 26Mbps, usually around 36 Mbps
Affecting kids xbox and firestick big time
Anonymous
Not applicable
Message 10 of 15
As I said if you can create the BQM I mentioned it could help diagnose your issue.
