Myopicmonkey
  • 13
Message 1 of 12
Sudden rise in packet loss to 30%
Morning everyone.
I'd like to report a sudden loss in connection quality that started at 11:45pm (ish) last night.  My connection has been fine for some considerable time and then last night dropped completely for around 15 minutes. Once reconnected it looked like this...
I've checked my PC and rebooted the cable modem with no improvement and there don't appear to be any known service interruptions in my area.
Any suggestions ?
Myopicmonkey
  • 13
Message 2 of 12
Re: Sudden rise in packet loss to 30%
12990000002.736256 qam21
21390000009.138256 qam1
3147000000937256 qam2
41550000008.437256 qam3
51630000007.537256 qam4
61710000007.537256 qam5
7179000000737256 qam6
81870000006.937256 qam7
91950000006.538256 qam8
10203000000637256 qam9
112110000005.637256 qam10
122190000005.137256 qam11
13227000000537256 qam12
142350000004.837256 qam13
152430000004.837256 qam14
162510000004.638256 qam15
172590000004.538256 qam16
18267000000438256 qam17
192750000003.537256 qam18
202830000002.937256 qam19
212910000002.937256 qam20
22307000000336256 qam22
23315000000337256 qam23
24323000000337256 qam24
1Locked36.6100
2Locked38.6519
3Locked37.640
4Locked37.350
5Locked37.610
6Locked37.630
7Locked37.380
8Locked37.660
9Locked38.640
10Locked37.670
11Locked37.650
12Locked37.650
13Locked37.650
14Locked37.630
15Locked37.650
16Locked38.650
17Locked38.650
18Locked38.960
19Locked37.350
20Locked37.370
21Locked37.6120
22Locked36.650
23Locked37.350
24Locked37.360
Myopicmonkey
  • 13
Message 3 of 12
13940000040.5512032 qam6
22580000042512032 qam8
33260000040.5512032 qam7
44620000040512032 qam5
3ATDMA0000
4ATDMA0000
Myopicmonkey
  • 13
Message 4 of 12
25/05/2021 06:48:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/05/2021 06:31:51noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 23:04:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 23:04:16criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 23:03:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 23:03:36criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:54:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:54:57criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:53:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:53:37criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:52:11criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:52:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:52:2criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:51:41criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:51:11Warning!TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:51:11criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:51:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:50:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2021 22:50:16criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Myopicmonkey
  • 13
Message 5 of 12
Issue seems to have ceased as of around 10:30am today. Will continue to monitor.
Corey_C
  • 5.19K
  • 257
  • 446
Moderator
Moderator
Message 6 of 12
Thanks for your post and reaching out to the community forums, Myopicmonkey,
Apologies for the late reply, glad to hear the issues have ceased. Do keep us updated.
Cheers,
Corey C
risc19
  • 849
  • 27
  • 253
Well-informed
Message 7 of 12
Keep an eye on your downstream power levels mate.
One is at 9.1 and others are at 2.1 thats too large a difference.
They should be between power should be always between -6 to +10 and as close together as possible.
Also you upstream modulations should read 64QAM not 32QAM.
Have another look to see if they have sorted themselves out.
My Broadband Ping - Virgin Lagfest Modem Mode
Myopicmonkey
  • 13
Message 8 of 12
The current monitor looks like this and has done for several days.
Current Router Status follows
12350000005.838256 qam13
21390000009.540256 qam1
3147000000938256 qam2
41550000008.538256 qam3
51630000007.938256 qam4
61710000007.638256 qam5
71790000007.438256 qam6
81870000007.338256 qam7
9195000000740256 qam8
102030000006.838256 qam9
112110000006.440256 qam10
12219000000640256 qam11
132270000005.938256 qam12
142430000005.938256 qam14
15251000000640256 qam15
162590000005.540256 qam16
172670000005.540256 qam17
18275000000540256 qam18
192830000004.938256 qam19
202910000004.938256 qam20
212990000005.338256 qam21
223070000005.438256 qam22
233150000005.538256 qam23
243230000005.638256 qam24
1Locked38.62522197
2Locked40.31691007
3Locked38.9194728
4Locked38.9221770
5Locked38.62273250
6Locked38.6199815
7Locked38.6211934
8Locked38.92011965
9Locked40.9238922
10Locked38.92452111
11Locked40.3246817
12Locked40.92231558
13Locked38.9271881
14Locked38.92841479
15Locked40.3249912
16Locked40.3214910
17Locked40.9230885
18Locked40.9312962
19Locked38.93431129
20Locked38.63881468
21Locked38.6407958
22Locked38.63391621
23Locked38.63651120
24Locked38.92991636
Myopicmonkey
  • 13
Message 9 of 12
13260000039512064 qam7
22580000039512064 qam8
33940000039.3512064 qam6
44620000039512064 qam5
3ATDMA0020
4ATDMA0000
Myopicmonkey
  • 13
Message 10 of 12
Do the downsteam/upstream levels levels still look out of whack to anyone?
I appreciate the help!
Martin
