Sudden Packetloss and loss of VOIP
farske
Hiya,
Yesterday I was wrought with connection issues, with packet loss, and VoIP failure.
I could still send messages, I could still view pages, but video games, connections, discord, skype, slack, all of them refused to hold a connection.
An oddity was with Discord voice and video, I could see and hear people in the chat, but they could not see or hear me.
Websites randomly timeout, frequently and often.
My PC has been updated, my hubs and router has all been restarted.
Today I just hit the same issues again, and lost VOIP which was a bit awkward mid-meeting.
Checks online and no issues found.
Any known issues in my area that are not reported online?
Anything I can do to resolve this sudden lack of VOIP and reliability?
Tests below:
See BQM:
2fa667144ef45aebac93e47350ca4a3ff01af13c-15-09-2022
3.0 Downstream channels
253310000003.70000140.366287QAM25625
11390000001.29999940.946209QAM2561
21470000001.29999940.946209QAM2562
31550000001.59999840.946209QAM2563
41630000001.79999940.946209QAM2564
51710000002.09999840.946209QAM2565
61790000002.29999940.366287QAM2566
71870000002.29999940.366287QAM2567
81950000002.40000240.946209QAM2568
92030000002.50000040.366287QAM2569
102110000002.59999840.366287QAM25610
112190000002.59999840.366287QAM25611
122270000002.59999840.366287QAM25612
132350000002.29999940.366287QAM25613
142430000002.29999940.366287QAM25614
152510000002.29999940.946209QAM25615
162590000002.79999940.946209QAM25616
172670000002.90000240.366287QAM25617
182750000002.70000140.946209QAM25618
192830000002.29999940.946209QAM25619
202910000002.59999840.946209QAM25620
212990000004.00000040.366287QAM25621
223070000004.50000040.366287QAM25622
233150000004.30000340.946209QAM25623
243230000004.00000040.366287QAM25624
263390000003.90000240.946209QAM25626
273470000004.19999740.946209QAM25627
283550000004.00000040.946209QAM25628
293630000003.90000240.366287QAM25629
303710000004.00000040.946209QAM25630
313790000004.09999840.946209QAM25631
37 REPLIES 37
farske
25 Locked 40.366287 0 0
1 Locked 40.946209 0 0
2 Locked 40.946209 0 0
3 Locked 40.946209 0 0
4 Locked 40.946209 0 0
5 Locked 40.946209 0 0
6 Locked 40.366287 0 0
7 Locked 40.366287 0 0
8 Locked 40.946209 0 0
9 Locked 40.366287 0 0
10 Locked 40.366287 0 0
11 Locked 40.366287 0 0
12 Locked 40.366287 0 0
13 Locked 40.366287 0 0
14 Locked 40.366287 0 0
15 Locked 40.946209 0 0
16 Locked 40.946209 0 0
17 Locked 40.366287 0 0
18 Locked 40.946209 0 0
19 Locked 40.946209 0 0
20 Locked 40.946209 0 0
21 Locked 40.366287 0 0
22 Locked 40.366287 0 0
23 Locked 40.946209 0 0
24 Locked 40.366287 0 0
26 Locked 40.946209 0 0
27 Locked 40.946209 0 0
28 Locked 40.946209 0 0
29 Locked 40.366287 0 0
30 Locked 40.946209 0 0
31 Locked 40.946209 0 0
3.1 Downstream channels
33 96 4K 1880 QAM4096 424
33 Locked 44 4.8 231857895 2577
3.0 Upstream channels
1 49600000 44.270599 5120 KSym/sec 64QAM 1
2 36600000 44.020599 5120 KSym/sec 64QAM 3
3 30100000 43.770599 5120 KSym/sec 64QAM 4
4 23600000 43.770599 5120 KSym/sec 16QAM 5
5 43100000 44.020599 5120 KSym/sec 64QAM 2
1 US_TYPE_STDMA 0 0 0 0
2 US_TYPE_STDMA 0 0 0 0
3 US_TYPE_STDMA 0 0 18 0
4 US_TYPE_STDMA 0 0 17 0
5 US_TYPE_STDMA 0 0 0 0
3.1 Upstream channels
6 10.8 39.8 2K QAM8
6 OFDMA 220 53.4 17 0
https://www.thinkbroadband.com/speedtest/1663241033849517355
Natalie_L
Hi Farske,
Thank you for reaching out to us here on the Community.
I am very sorry to hear you are experiencing issues with your service.
Can you please confirm if the devices impacted are connected to the Hub via WiFi or Ethernet?
Can you also please check that your connection to the Hub are secure and without damage?
Nat
farske
Ethernet, I have a selection of ethernet linked pcs and devices.
The hub connection is fine, yes 🙂
Hi there!
I too am in the same boat as you, and have contacted VIRGIN about this problem, and have found out ,they have a serious isuue in my area CR5, and are working hard to fix this problem,BUT as it is a "complex issue" , their words,it may take some time!! , i have had 7 days out of the last 14 , with this problem( weirdly random days it is ok ) .
I have now just spoken to VIRGIN media via a landline phone, and have been told there is a "complex issue" in my area that needs fixing, and will take a further 4days to find and fix.
its a pity they do not think it is right to tell us of this problem,and let us think it is our end that is the problem,so we come on here to ask for help,and end up trying everything here first!!
Hello bigguy283.
Thank you very much for joining our Community.
Can I just apologise for poor the connection you are having.
We have ran a few tests from here and checked your equipment.
Sadly we do have an SNR issue in the area.
This is logged under reference number F010115708  and is due to be fixed on the 26/09 at 10:25am.
If it is still an issue tomorrow, Please pop back on here and we can take a look again for you.
Gareth_L
thnx gareth
i will let you know 26th if issue is better, i thought it was better sat 24th BUT not really ,as i could not upstream to my daughter as kept buffering and dropping connection! , also on your website to check my connection, it kept trying ,only to say "opps unfortunately we are unable to check"  all the time after a few minutes!
but again hopefully tomorrow after 10:30  i wll let you know, p.s when i spoke to your customer service about this , i was told they knew of this problem, and was expecting it to be fixed by the 26th!
farske
I am still having issues, today I have had constant connection drops.
It says its all fine on check, but its clearly not easily detectable.
farske
See here:
See here:
My Broadband Ping - VM HUB4 1GB
Hi there farske,
Thanks for posting updates regarding this. From checking our service today I can't currently find any readings that would attribute to the loss that you experienced on Monday.
Are the issues still present?
Let us know,
Kain
