elJambo
  • 41
Message 1 of 5
Sudden Loss of Upload Speed and Intermittent Loss of Broadband
On Monday night my connection suddenly dropped out. For the rest of the night my connection was intermittent
Previous to Monday I consistently got max speeds for my 360-382 down and 36 wired and over wifi. From Today (Tuesday) my download speed is all over the place. Anywhere from 10mb to full speed. Upload speed doesn't get over 10, but often only 1meg.
Im on a hub 3. I've done the usual reset. Cable into the router seems fine.
VM Status check does not detect any errors.
Getting loads of errors in the network log:
25/08/2020 21:57:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 21:53:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 20:11:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 20:11:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 19:01:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 14:39:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 14:33:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 14:30:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 14:28:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 14:28:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 14:25:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 14:23:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/08/2020 14:23:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 2 of 5
Re: Sudden Loss of Upload Speed and Intermittent Loss of Broadband
Could you post the 'Downstream' and 'Upstream' tab data?
We can have a look for any oddities in the stats.
elJambo
  • 41
Message 3 of 5
11390000003.538256 qam1
21470000003.538256 qam2
31550000003.738256 qam3
41630000003.738256 qam4
51710000003.738256 qam5
61790000003.738256 qam6
71870000003.538256 qam7
81950000003.538256 qam8
92030000003.238256 qam9
10211000000338256 qam10
112190000002.938256 qam11
122270000002.538256 qam12
132350000002.238256 qam13
142430000002.238256 qam14
152510000002.538256 qam15
162590000002.538256 qam16
172670000002.938256 qam17
182750000002.738256 qam18
192830000002.738256 qam19
202910000002.538256 qam20
212990000002.538256 qam21
223070000002.538256 qam22
233150000002.538256 qam23
243230000002.538256 qam24
1Locked38.940702483709
2Locked38.642949114116
3Locked38.965121100321
4Locked38.927614360105
5Locked38.965339102958
6Locked38.93378467095
7Locked38.628850
8Locked38.980
9Locked38.950
10Locked38.640
11Locked38.960
12Locked38.660
13Locked38.980
14Locked38.9110
15Locked38.9110
16Locked38.660
17Locked38.980
18Locked38.650
19Locked38.950
20Locked38.960
21Locked38.970
22Locked38.950
23Locked38.950
24Locked38.950
1603000004.7512064 qam1
2394000004.625512064 qam4
3462000004.675512064 qam3
4537000004.65512064 qam2
3ATDMA0000
4ATDMA0000
elJambo
  • 41
Message 4 of 5
Any ideas?
Anonymous
Not applicable
Message 5 of 5
Power levels look ok.
Some of your channels, however, appear to have a large number of errors. If these have built up over a short period of time this points to an issue with your line.
It could also be a hardware (HUB) issue.
