Try this first...
________________________________________
Have you checked first for “known network faults”
As well as trying the “check service,”Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level.
Also you weren't "upgrading" to a Hub5 - it isn't on general release -it is just being offered to a few "selected" customers - you are effectively beta-testing their new hardware for any faults/limitations/issues.
If the problems persist you should call in to get your old Hub re-activated - or if you dont still have it - get them to send you one out and return the Hub5 - until is fully released
