ASW2037
Stopping and starting in i player
While watching programmes on I-player it stops and starts every few minutes as it appears to wait for more to load.
  • 16.31K
  • 712
  • 1.6K
Re: Stopping and starting in i player
Is it by wireless?
ASW2037
It’s direct cable to the TiVo Box.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Which one of these three set ups are you using ?
V6-connection
tivo-v6
ASW2037
Hi Mike, the setup is item 3
I picked up on a thread that clearing all suggestions might help so spent time doing that plus deleting all recorded suggestion, strangely it appears to have had some impact unless in a twist of fate there was a problem which cleared at the same time.
I am still open to suggestions to fix this as stopping the TiVo box doing something it’s designed is not the right way
cheers Bob
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
It is a few years since I used a Tivo and when it did have problems i just did a full clear & reset on it.
Everything was lost but it only too a few minutes to set up the favourites list and all other functions are readily available through other apps.
