@Zach_R wrote:
Hi @saracen3,
Thank you for your posts and welcome back to our community forums. We're here to help.
I'm very sorry to hear that you're having some problems with your connection speeds. To clarify, are you saying that two specific devices are facing slow speeds on a wired connection, but that all other devices - wired or wireless/Wi-Fi - are receiving acceptable speeds?
come on @Zach_R why ask the question - its all there - thats exactly what the OP is saying - hmmmmmmmmmmmmm
to the OP - as said if you have the speed at the hub and wifi speeds on some devices then the problem is your side - safe mode with networking is the test you need to do on the windows pc's - check in control panel/devices the spec of the lan cards and post back - also check they are set to gigabit not 10/100
if that does not give good speeds then hub into modem mode and repeat safe mode test with just one pc connected via your cat7 cable
do you have any other things in the circuit - a switch for example
____________________
Tony.
Sacked VIP
