15-07-2021 22:57 - edited 15-07-2021 23:10
Hi all.
I am starting see a lot of noise on the downstream channels, I have checked that all of my connections are tight.
The LED ring has failed around the front of the Hub 4, on Gig1 also not sure that it matters. Hub is in router mode for the time being.
Channel 18 has always given me issues. Noise on 1 to 11 is new.
Latency.
Logs to follow.
on 15-07-2021 23:04
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
3.0 Downstream channels
3 | 155000000 | 6.099998 | 40.366287 | QAM256 | 3 |
1 | 139000000 | 7.000000 | 40.946209 | QAM256 | 1 |
2 | 147000000 | 6.300003 | 40.366287 | QAM256 | 2 |
4 | 163000000 | 6.099998 | 40.946209 | QAM256 | 4 |
5 | 171000000 | 5.900002 | 40.366287 | QAM256 | 5 |
6 | 179000000 | 5.900002 | 40.946209 | QAM256 | 6 |
7 | 187000000 | 5.800003 | 40.366287 | QAM256 | 7 |
8 | 195000000 | 5.699997 | 40.366287 | QAM256 | 8 |
9 | 203000000 | 5.500000 | 40.946209 | QAM256 | 9 |
10 | 211000000 | 5.300003 | 40.946209 | QAM256 | 10 |
11 | 219000000 | 5.099998 | 40.366287 | QAM256 | 11 |
12 | 227000000 | 5.000000 | 40.946209 | QAM256 | 12 |
13 | 235000000 | 5.099998 | 40.366287 | QAM256 | 13 |
14 | 243000000 | 5.300003 | 40.366287 | QAM256 | 14 |
15 | 251000000 | 5.300003 | 40.366287 | QAM256 | 15 |
16 | 259000000 | 5.800003 | 40.946209 | QAM256 | 16 |
17 | 267000000 | 6.199997 | 40.946209 | QAM256 | 17 |
18 | 275000000 | 6.199997 | 38.605377 | QAM256 | 18 |
19 | 283000000 | 5.900002 | 40.366287 | QAM256 | 19 |
20 | 291000000 | 5.900002 | 40.366287 | QAM256 | 20 |
21 | 299000000 | 5.699997 | 40.946209 | QAM256 | 21 |
22 | 307000000 | 6.199997 | 40.946209 | QAM256 | 22 |
23 | 315000000 | 6.300003 | 40.366287 | QAM256 | 23 |
24 | 323000000 | 6.599998 | 40.366287 | QAM256 | 24 |
25 | 363000000 | 6.400002 | 40.946209 | QAM256 | 25 |
26 | 371000000 | 6.400002 | 40.366287 | QAM256 | 26 |
27 | 379000000 | 6.400002 | 40.946209 | QAM256 | 27 |
28 | 387000000 | 6.099998 | 40.946209 | QAM256 | 28 |
29 | 395000000 | 6.000000 | 40.946209 | QAM256 | 29 |
30 | 403000000 | 5.900002 | 40.946209 | QAM256 | 30 |
31 | 411000000 | 5.699997 | 40.366287 | QAM256 | 31 |
3 | Locked | 40.366287 | 10610 | 0 |
1 | Locked | 40.946209 | 1479 | 0 |
2 | Locked | 40.366287 | 16066 | 0 |
4 | Locked | 40.946209 | 10054 | 0 |
5 | Locked | 40.366287 | 5757 | 0 |
6 | Locked | 40.946209 | 2624 | 0 |
7 | Locked | 40.366287 | 16137 | 0 |
8 | Locked | 40.366287 | 10457 | 0 |
9 | Locked | 40.946209 | 4247 | 0 |
10 | Locked | 40.946209 | 2946 | 0 |
11 | Locked | 40.366287 | 15769 | 0 |
12 | Locked | 40.946209 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.366287 | 0 | 0 |
16 | Locked | 40.946209 | 0 | 0 |
17 | Locked | 40.946209 | 0 | 0 |
18 | Locked | 38.605377 | 27085117 | 9675 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.946209 | 0 | 0 |
22 | Locked | 40.946209 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
25 | Locked | 40.946209 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.946209 | 0 | 0 |
28 | Locked | 40.946209 | 0 | 0 |
29 | Locked | 40.946209 | 0 | 0 |
30 | Locked | 40.946209 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 42 | 6.4 | 326487287 | 0 |
on 15-07-2021 23:08
3.0 Upstream channels
1 | 53700000 | 47.520599 | 5120 KSym/sec | 64QAM | 2 |
2 | 39400000 | 46.770599 | 5120 KSym/sec | 64QAM | 4 |
3 | 46200000 | 47.270599 | 5120 KSym/sec | 64QAM | 3 |
4 | 60300000 | 48.270599 | 5120 KSym/sec | 64QAM | 1 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
General Configuration
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | ncxv9873254k;fg87dsfd;kfo |
SFID | 794 |
Max Traffic Rate | 1200000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 793 |
Max Traffic Rate | 55000270 |
Max Concatenated Burst | 16320 |
Scheduling Type | bestEffort |
Mon May 24 07:08:54 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon May 24 07:08:54 2021 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed May 26 12:12:51 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu May 27 19:08:54 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu May 27 19:08:54 2021 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri May 28 15:10:37 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon May 31 07:08:54 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon May 31 07:08:54 2021 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jun 3 03:35:54 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jun 3 19:08:54 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jun 3 19:08:54 2021 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Jun 4 01:31:48 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 7 07:08:54 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 7 07:08:55 2021 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Jun 9 07:37:41 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jun 10 19:08:55 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jun 10 19:08:55 2021 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 14 07:08:55 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 14 07:08:55 2021 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jun 17 03:10:40 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jun 17 19:08:55 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jun 17 19:08:55 2021 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Jun 19 07:52:36 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Jun 21 07:08:55 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 16-07-2021 00:32
on 16-07-2021 15:35
on 18-07-2021 15:54
Good afternoon @rs888
I have taken a further look over the account, all the power levers are where they are supposed to be. There is nothing on the network to indicate that this is the issue.
The hub hasn't been rebooted for 9 days, please could you pinhole set the hub.
Kind regards,
Zak_M
19-07-2021 20:06 - edited 19-07-2021 20:06
on 19-07-2021 20:10
1 | 139000000 | 6.699997 | 40.366287 | QAM256 | 1 |
2 | 147000000 | 6.199997 | 40.946209 | QAM256 | 2 |
3 | 155000000 | 5.800003 | 40.366287 | QAM256 | 3 |
4 | 163000000 | 5.900002 | 40.946209 | QAM256 | 4 |
5 | 171000000 | 5.699997 | 40.946209 | QAM256 | 5 |
6 | 179000000 | 5.599998 | 40.946209 | QAM256 | 6 |
7 | 187000000 | 5.500000 | 40.946209 | QAM256 | 7 |
8 | 195000000 | 5.400002 | 40.366287 | QAM256 | 8 |
9 | 203000000 | 5.199997 | 40.946209 | QAM256 | 9 |
10 | 211000000 | 5.099998 | 40.946209 | QAM256 | 10 |
11 | 219000000 | 5.000000 | 40.946209 | QAM256 | 11 |
12 | 227000000 | 4.800003 | 40.946209 | QAM256 | 12 |
13 | 235000000 | 4.800003 | 40.366287 | QAM256 | 13 |
14 | 243000000 | 5.000000 | 40.366287 | QAM256 | 14 |
15 | 251000000 | 5.000000 | 40.946209 | QAM256 | 15 |
16 | 259000000 | 5.500000 | 40.946209 | QAM256 | 16 |
17 | 267000000 | 5.800003 | 40.366287 | QAM256 | 17 |
18 | 275000000 | 5.800003 | 38.605377 | QAM256 | 18 |
19 | 283000000 | 5.500000 | 40.366287 | QAM256 | 19 |
20 | 291000000 | 5.500000 | 40.366287 | QAM256 | 20 |
21 | 299000000 | 5.199997 | 40.946209 | QAM256 | 21 |
22 | 307000000 | 5.599998 | 40.366287 | QAM256 | 22 |
23 | 315000000 | 5.800003 | 40.366287 | QAM256 | 23 |
24 | 323000000 | 6.099998 | 40.366287 | QAM256 | 24 |
25 | 363000000 | 5.900002 | 40.366287 | QAM256 | 25 |
26 | 371000000 | 5.800003 | 40.366287 | QAM256 | 26 |
27 | 379000000 | 5.800003 | 40.946209 | QAM256 | 27 |
28 | 387000000 | 5.699997 | 40.946209 | QAM256 | 28 |
29 | 395000000 | 5.500000 | 40.366287 | QAM256 | 29 |
30 | 403000000 | 5.300003 | 40.366287 | QAM256 | 30 |
31 | 411000000 | 5.099998 | 40.946209 | QAM256 | 31 |
1 | Locked | 40.366287 | 718 | 0 |
2 | Locked | 40.946209 | 246 | 0 |
3 | Locked | 40.366287 | 208 | 0 |
4 | Locked | 40.946209 | 604 | 0 |
5 | Locked | 40.946209 | 63 | 0 |
6 | Locked | 40.946209 | 146 | 0 |
7 | Locked | 40.946209 | 338 | 0 |
8 | Locked | 40.366287 | 754 | 0 |
9 | Locked | 40.946209 | 40 | 0 |
10 | Locked | 40.946209 | 147 | 0 |
11 | Locked | 40.946209 | 242 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 38.605377 | 3343206 | 183 |
22 | Locked | 40.366287 | 0 | 0 |
25 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.946209 | 0 | 0 |
159 | Locked | 42 | 5.3 | 101329485 | 0 |
on 19-07-2021 20:11
1 | 39400000 | 47.770599 | 5120 KSym/sec | 64QAM | 4 |
2 | 46200000 | 48.270599 | 5120 KSym/sec | 64QAM | 3 |
3 | 53700000 | 48.770599 | 5120 KSym/sec | 64QAM | 2 |
4 | 60300000 | 49.270599 | 5120 KSym/sec | 64QAM | 1 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
Thu Jan 1 00:01:30 1970 | 4 | Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:50 1970 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Jul 18 19:25:12 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Jul 18 19:37:26 2021 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 19-07-2021 20:35
Your problem appears to me likely to be down to noise ingress on 275 MHz, visible as post-RS (uncorrectable) errors on the downstream, both before and after the restart. The higher number of pre-RS errors isn't materal as those are corrected on the fly, but the difference between channels confirms what the post-RS data shows. That frequency could easily be a UHF military radio system, as that frequency is commonly used for airfield comms or approach radars, but that's largely academic as the problem is not the source, but that there's a fault on VM's coax that's allowing that in as radio frequency noise.
And that's what VM need to send out a man to fix.
