Redjanet
  • 17
Message 1 of 17
Speeds not up to scratch
Hello,
I have an M100 account and for quite some weeks now, our download and upload speeds during working hours are not very good.
I have just run the speed test linked to on Virgin's help pages and these are my results. If someone could please offer some simple advice, or book an engineer visit it would be appreciated. I have done all of the usual things such as turning off and on again, unplugging and replugging, resetting the hub. This works temporarily but just gets worse again. Thank you in advance for any help provided.
conman33158
  • 873
  • 81
  • 123
Superfast
Message 2 of 17
Re: Speeds not up to scratch
Can you please upload your router stats
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
For Hubs 2 & 3 - DO NOT LOG IN, just click “Check Router Status”
For Hub 4 - When the page appears LOG IN then click on:
Advanced Settings > Tools > Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again. You can use more than one post for each item if needed.
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Post a 'Live Link' to your BQM on here asap.
Under your graph you just created Click (Share Live Graph) then click generate.
Copy the text in the Direct Link box and paste it on here
Redjanet
  • 17
Message 3 of 17
Downstream
1402750000938256 qam30
22027500009.537256 qam9
32107500009.337256 qam10
4218750000937256 qam11
52267500008.837256 qam12
62347500008.837256 qam13
72427500008.537256 qam14
82507500008.637256 qam15
92587500008.837256 qam16
102667500008.837256 qam17
112747500008.837256 qam18
122827500009.337256 qam19
132907500009.537256 qam20
142987500009.837256 qam21
153067500009.537256 qam22
163147500009.337256 qam23
173227500009.337256 qam24
183307500009.338256 qam25
19370750000938256 qam26
20378750000937256 qam27
213867500008.637256 qam28
22394750000938256 qam29
234107500009.438256 qam31
244187500009.338256 qam32
1Locked38.6402010312
2Locked37.6145510264
3Locked37.39339492
4Locked37.614659914
5Locked37.3144410643
6Locked37.3151810922
7Locked37.612413666
8Locked37.612093778
9Locked37.3122112980
10Locked37.3130213470
11Locked37.3119913841
12Locked37.3126613875
13Locked37.638398767
14Locked37.3187813554
15Locked37.6167713504
16Locked37.3179513305
17Locked37.6115911446
18Locked38.632479880
19Locked38.634637649
20Locked37.6113013374
21Locked37.343978372
22Locked38.642707609
23Locked38.6447213158
24Locked38.9399814885
Upstream
13940000040.3512064 qam3
23260000038.8512064 qam4
34620000041.8512064 qam2
45370000042.3512064 qam1
1ATDMA00170
2ATDMA0070
3ATDMA00140
4ATDMA00140
Redjanet
  • 17
Message 4 of 17
Upstream
1ATDMA00170
2ATDMA0070
3ATDMA00140
4ATDMA00140
Redjanet
  • 17
Message 5 of 17
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
;fg87dsfd;kfoA,.iyewrkldJ
SFID21390
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID16867
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Redjanet
  • 17
Message 6 of 17
Network log
03/02/2021 11:45:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/02/2021 11:45:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/02/2021 11:45:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/02/2021 11:45:50Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Redjanet
  • 17
Message 7 of 17
Apologies for the multiple messages.
This is the live graph link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/c3a1a870089af49ac883351011f29a7631632626
conman33158
  • 873
  • 81
  • 123
Superfast
Message 8 of 17
Your BQM is not showing properly. Can you go into your Firewall settings and untick “Block fragmented IP packets”
Also, are you testing speed wireless or wired?
Redjanet
  • 17
Message 9 of 17
I will have to try to post the BQM later on a different machine. I am working on a company-owned laptop and I do not have access to the firewall settings. I am working on a wireless connection.
conman33158
  • 873
  • 81
  • 123
Superfast
Message 10 of 17
When using wireless make sure your connected to the 5Ghz band for a faster speed as you are probably connected to 2.4Ghz.
What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
  1. Make sure the cable is Cat 5e or better
  2. Make sure your PC/laptop has a 1Gbps or better network card
  3. Make sure Hub is in router mode
  4. Disconnect all other Ethernet cables when running the test
