on 24-08-2023 11:52
Hi , so I've purchased the 1gb Internet, I have a WiFi pod in the same room as my PlayStation thats also connected by ethernet ,
TThe hub speed says I'm pulling 1gb , my WiFi speed test will vary from 2mbs - 600mbs
But my PlayStation or xbox won't go over 60mbs WiFi or ethernet ccable this is the highest I've been able to get it , average is between 3mbs and 20mbs ,
How can i solve this please ? Theres no consistency
on 24-08-2023 14:49
I remember my initial upgrade from TalkTalk 35Mbs to Virgin M200. My son was super excited that he would download files very fast but max we got was about 50Mbs LOL.
After some google search we had to change the DNS server on PlayStation setting to
Primary 8.8.4.4 and Secondary 8.8.8.8 and this did increase the speed. But I don't think we ever got the max speed to match M200 as there maybe limitation from the PlayStation server. Below is some bedtime reading for you 🙂
https://www.increasebroadbandspeed.co.uk/guide-best-fastest-dns-servers-ps4
on 24-08-2023 16:21
"I have a WiFi pod in the same room as my PlayStation" - Oh la la ... that is a classic school boy error !
DNS changes are only required if the VM DNS is not working or you wish to bypass Child & Virus Safe.
Place the VM Pod correctly i.e. mid way between the Hub and the Rooms needing better coverage.
on 24-08-2023 16:29
Why I'd it an error when I want better coverage in that room and to connect it via ethernet ?
on 24-08-2023 16:39
1) Using the VM Pod as an external Wi-Fi adaptor is just another form of Wi-Fi connection.
2) Having the VM Pod close to the Playstation means it is totally redundant at that location
3) Use a longer network cable to run from the Hub direct to the Playstation if an Ethernet connection is desired
24-08-2023 16:41 - edited 24-08-2023 17:02
Run this link in a web browser to see Hub and device speeds ...
The speed at the Hub should reflect your subscription.
The speed any WiFi device draws data at is limited by its data needs and technical abilities.
on 24-08-2023 21:33
okay moving the pod seems to have stabilised it but still not getting anywhere near top speed on console -
do you know why when i log onto - http://192.168.0.1/ to look at setting or attempt to port forward my ps5 hub3 comes up when i have a hub 5 ? so not been able to get into it
on 24-08-2023 22:01
The best speeds over Wi-Fi with a Hub and the VM Pod i.e. a Repeater are not possible because using even 1 repeater halves the bandwidth due to the half duplex nature of Wi-Fi.
Some of the first Hub 5's had a blooper in the firmware that said Hub 3, amazing how bad a tiny typo can look.
But that should not stop you using the Hub's menus.
on 24-08-2023 22:04
i see okay , thanks for the info here , if possible would you suggest moving the hub into the office/games room ?
i cant access the hub menus unfortunately it tells me the password is wrong while showing hub 3, on the rare occasion it shows hub 5 installer it always crashes
on 25-08-2023 07:45
VM charge a flat fee of £25 to re-cable for a Hub in a different room.
Perhaps a 60 second press on the rear RESET button would revert the Hub to the factory passwords.
