adammarshall
  • 5
Message 1 of 7
Speeds inconsistent and slow after upgrade
After upgrading my internet package from 100Mbps to 350Mbps yesterday (16/01/2021) I'm encountering slow and inconsistent speeds. Sometimes I can get 250Mbps download and 36Mbps upload, to 80Mbps download and 4Mbps upload an hour later.
I have a wired connection and I've restarted my router a couple of times in an attempt to resolve the issue.
Tags (2)
Andruser
  • 5.53K
  • 970
  • 2.28K
Message 2 of 7
Re: Speeds inconsistent and slow after upgrade
Possibly a pre-existing noise issue that you barely noticed is now preventing the higher speeds being delivered consistently.  Connect to the hub by clicking on this link http://192.168.0.1/  That should pull up the log in page for the hub.  But don't log in, just click on the link "Check router status"  That'll bring up a window with five tabs.  Open the Downstream tab.  Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here.  Post that, do the same for the Upstream and Network log.  You'll get an error message when you post the Network log, just click on "post" a second time.  Don't post screenshots.
Then we can check the power, noise and error stats to see if there's anything in them that would explain this.
adammarshall
  • 5
Message 3 of 7
12270000005.140256 qam12
22190000004.840256 qam11
3235000000540256 qam13
42430000004.340256 qam14
52510000004.840256 qam15
62590000004.440256 qam16
72670000004.140256 qam17
82750000004.540256 qam18
92830000004.540256 qam19
102910000004.540256 qam20
112990000004.640256 qam21
123070000004.840256 qam22
13315000000540256 qam23
143230000004.540256 qam24
15331000000540256 qam25
163710000004.540256 qam26
173790000004.640256 qam27
18387000000540256 qam28
193950000004.540256 qam29
204030000004.340256 qam30
214110000004.640256 qam31
224190000004.540256 qam32
23427000000440256 qam33
244350000003.740256 qam34
1Locked40.3260
2Locked40.9190
3Locked40.3150
4Locked40.9110
5Locked40.980
6Locked40.390
7Locked40.390
8Locked40.370
9Locked40.360
10Locked40.980
11Locked40.3230
12Locked40.3110
13Locked40.9270
14Locked40.360
15Locked40.32920
16Locked40.33390
17Locked40.31400
18Locked40.31320
19Locked40.31660
20Locked40.31450
21Locked40.33330
22Locked40.32660
23Locked40.31180
24Locked40.32480
13940000042.5512064 qam2
22579997142.8512064 qam4
33260000042.8512064 qam3
44620000043.3512064 qam1
2ATDMA0010
3ATDMA0000
4ATDMA0000
adammarshall
  • 5
Message 4 of 7
18/01/2021 07:13:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 22:04:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 19:19:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 13:39:2criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 13:35:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 13:32:18Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 13:32:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 13:32:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 13:32:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:59:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:18:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:18:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:18:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 09:16:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 08:53:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 03:25:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 01:26:8criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andruser
  • 5.53K
  • 970
  • 2.28K
Message 5 of 7
There's nothing obviously wrong in those stats (power is good, SNR is good, error count is acceptable, modulation is fine), although the network log indicaates an unreliable connection.
Setup a BQM, that'll show what's going on with your VM connection.  Post a link to a live, shared graph here and we'll see what's happening.  Usually needs to run for 24 hours before we can draw reasonable conclusions, but the live graph will continuously update so you can do that immediately.
adammarshall
  • 5
Message 6 of 7
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d7de8de8359aeb0d0f2e23e71d819d8157767e19
adammarshall
  • 5
Message 7 of 7
Ok the broadband tracker has been running for over 24 hours now. Any conclusions you can draw?
