S1978
  • 9
Message 1 of 14
Speed
Hi, hope someone can help me! At the end of my tether with broadband speed being slow, just upgraded to M350 however Internet speed test is always around 30 mbps! 2 children who like to game online and stream, always moaning that it's lagging etc. Done all the resets, and suggestions on virgin connect etc. Help!
Andrew-G
  • 9.53K
  • 1.54K
  • 4.56K
Message 2 of 14
Re: Speed
Follow the instructions below carefully:
Connect to the hub by clicking on this link http://192.168.0.1/  That should pull up the log in page for the hub.  But don't log in, just click on the link "Check router status"
That'll bring up a window with five tabs.  Open the Downstream tab.  Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots.
Post that, do the same for the Upstream and Network log.  You'll get an odd error message when you post the Network log, just click on "post" a second time.
Then we can check for any obvious problems with power, noise or error counts.
S1978
  • 9
Message 3 of 14
Re: Speed
HI, thank you for reply, when I click on link I get - 404 Not Found
  • 29.04K
  • 2.89K
  • 5.47K
Message 4 of 14
Re: Speed
Try on a different browser. Try connecting via ethernet cable rather than wifi (or vica versa) Or try http://192.168.100.1 - if in modem mode
S1978
  • 9
Message 5 of 14
Re: Speed
Tried that and says - this sire cant be reached.
What is modem mode?
S1978
  • 9
Message 6 of 14
Re: Speed
1331000000740256 qam25
22350000005.638256 qam13
32430000005.538256 qam14
42510000005.438256 qam15
52590000005.938256 qam16
6267000000638256 qam17
7275000000640256 qam18
82830000005.838256 qam19
92910000005.438256 qam20
102990000005.438256 qam21
113070000005.538256 qam22
123150000005.938256 qam23
133230000006.540256 qam24
143390000007.438256 qam26
153470000007.140256 qam27
16355000000740256 qam28
17363000000740256 qam29
18371000000740256 qam30
19379000000738256 qam31
20387000000738256 qam32
213950000007.138256 qam33
224030000007.540256 qam34
234110000007.938256 qam35
244190000007.540256 qam36
1Locked40.3430
2Locked38.9590
3Locked38.6350
4Locked38.9540
5Locked38.9470
6Locked38.9290
7Locked40.3680
8Locked38.95614
9Locked38.6630
10Locked38.9620
11Locked38.9520
12Locked38.9450
13Locked40.94713
14Locked38.9460
15Locked40.3510
16Locked40.3670
17Locked40.34317
18Locked40.3490
19Locked38.9520
20Locked38.9530
21Locked38.9370
22Locked40.3450
23Locked38.9700
24Locked40.3700
S1978
  • 9
Message 7 of 14
Re: Speed
15370000044512064 qam2
26030000044.5512064 qam1
33940000043.3512064 qam7
44620000043.5512064 qam3
1ATDMA0010
3ATDMA0000
4ATDMA0010
S1978
  • 9
Message 8 of 14
Re: Speed
02/06/2021 19:55:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/06/2021 18:06:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/06/2021 07:22:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/06/2021 07:06:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/06/2021 06:04:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/06/2021 05:41:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/06/2021 13:17:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/06/2021 10:57:41noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;31/05/2021 18:24:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/05/2021 12:47:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/05/2021 12:25:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/05/2021 21:43:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/05/2021 20:55:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/05/2021 15:48:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;24/05/2021 19:41:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;23/05/2021 16:41:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/05/2021 02:18:13ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/05/2021 10:27:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/05/2021 21:07:45ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
S1978
  • 9
Message 9 of 14
Re: Speed
Can anyone help please?
jpeg1
  • 6.12K
  • 318
  • 1.08K
Hero
Message 10 of 14
Re: Speed
According to these figures there isn't much wrong with your broadband connection. This sounds more like a WiFi problem.  Are your family all using WiFi?  If so you will need to look at improving the way that is set up.
What is the speed like with a device connected to the Hub with an ethernet cable ?
