Shauna2020
  • 12
Message 1 of 13
Speed
pay for 100mbps and I am receiving 493.1kbps wired connection! Called up and was told to do pin reset and all would be fine in 35 minutes, if that was the case I wouldn’t have been on the phone considering I did the pin reset yesterday and all was still the same today. Then was told it’s a problem with my router which I had made aware of 4 weeks ago when I lost my TV services and nothing was done about it but today I can have a new router ordered because apparently my services have been watched for the last 4 weeks and can see there’s an issue with my router but yet it took for me to sit 40 minutes on hold to speak to someone about my issue for them to acknowledge and order a router, why wasn’t it just ordered when the issue was noticed 4 weeks ago. Told I would get a call back in 35 mins to check if the pin reset worked and low and behold 1 hour and 30 mins later I’m still sat awaiting the call with my 493.1kbps speed. But quick enough to email and tell me my bill was due last week taking full payment for the speed I was sold rather than actually charging for what I’m receiving. Joke of a company all about the money, never once has anyone been helpful to resolve issues when I’ve contacted just pass you from pillow to post, as long as the moneys coming in eh!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 13
Re: Speed
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Shauna2020
  • 12
Message 3 of 13
Re: Speed
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
ewrkldJKDHSUBsgvca69834ncxv987325
SFID390
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID389
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Shauna2020
  • 12
Message 4 of 13
Re: Speed
Have no clue if that’s what you meant none of what you said made any sense to me (sorry)
Shauna2020
  • 12
Message 5 of 13
Re: Speed
Downstream
1
402750000
10
40
256 qam
30
2
202750000
6.5
38
256 qam
9
3
210750000
6.1
38
256 qam
10
4
218750000
6
38
256 qam
11
5
226750000
5.6
38
256 qam
12
6
234750000
5.6
38
256 qam
13
7
242750000
6
38
256 qam
14
8
250750000
6.3
38
256 qam
15
9
258750000
6.3
38
256 qam
16
10
266750000
6.5
38
256 qam
17
11
274750000
6.5
38
256 qam
18
12
282750000
6.9
38
256 qam
19
13
290750000
7.1
38
256 qam
20
14
298750000
8
38
256 qam
21
15
3
Shauna2020
  • 12
Message 6 of 13
Re: Speed
Upstream
1
39400000
4.375
5120
32 qam
2
2
25800000
4.375
5120
64 qam
4
3
32600000
4.225
5120
64 qam
3
4
46200000
4.375
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Shauna2020
  • 12
Message 7 of 13
Re: Speed
Network
05/11/2020 01:09:35
critical
04/11/2020 21:19:43
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 21:19:33
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 21:19:12
notice
04/11/2020 21:18:59
Warning!
01/01/1970 00:01:31
critical
04/11/2020 20:54:25
Warning!
04/11/2020 20:54:24
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 20:52:9
Warning!
04/11/2020 20:52:9
critical
04/11/2020 20:41:41
Warning!
04/11/2020 20:41:41
critical
04/11/2020 20:35:40
Warning!
04/11/2020 20:30:14
notice
04/11/2020 20:30:6
Warning!
04/11/2020 20:30:3
critical
04/11/2020 20:29:52
Warning!
04/11/2020 20:29:50
critical
04/11/2020 14:47:8
Warning!
04/11/2020 14:34:27
notice
SW download Successful - Via Config file
Shauna2020
  • 12
Message 8 of 13
Re: Speed
Zoie_P
  • 2.92K
  • 137
  • 236
Message 9 of 13
Re: Speed
Hi Shauna2020,
Welcome to forums and thank you for your post 🙂
I am sorry to hear this and I can look into this for you, I will pop you over a private message and take a look for you. Just keep an eye out for the purple envelope.
thanks,
Zoie
Shauna2020
  • 12
Message 10 of 13
Re: Speed
New hub arrived so I’m going to add the graph for the new hub
