Speed ????
What’s going on ? I’m supposed to be getting 150mps and I’m barely managing to get 20-30 with 1 device connected?? I’ve tried every step and test but nothing is making a difference. Not happy to be paying £55 a month for nothing .
  • 30.42K
  • 1.52K
  • 5.29K
Re: Speed ????
i'm guesing you are using wireles Wireless speeds are not garanteed you need to test wired
Re: Speed ????
Nope that’s wired connection.
  • 30.42K
  • 1.52K
  • 5.29K
Re: Speed ????
have you tested with any other devices? are you connected the hub diectly or using a switch/powerlines
please post the the modem stats and logs
