pda1984
  • 8
Message 1 of 10
Speed very slow intermittently
Our speed keeps dropping and becomes almost unusable at times.
just been upgraded to a new Hub 3.0 and worse than before. someone said it could be to do with power levels.
any thoughts would be appropriated
1331000000-4.537256 qam25
2235000000-4.538256 qam13
3243000000-4.538256 qam14
4251000000-4.738256 qam15
5259000000-4.538256 qam16
6267000000-4.237256 qam17
7275000000-438256 qam18
8283000000-438256 qam19
9291000000-3.938256 qam20
10299000000-3.737256 qam21
11307000000-3.738256 qam22
12315000000-437256 qam23
13323000000-4.537256 qam24
14371000000-4.737256 qam26
15379000000-4.737256 qam27
16387000000-4.937256 qam28
17395000000-4.738256 qam29
18403000000-4.937256 qam30
19411000000-537256 qam31
20419000000-537256 qam32
21427000000-4.937256 qam33
22435000000-538256 qam34
23443000000-5.238256 qam35
24451000000-5.438256 qam36
1Locked37.66390
2Locked38.6127324
3Locked38.614160
4Locked38.95380
5Locked38.63010
6Locked37.64330
7Locked38.65360
8Locked38.67890
9Locked38.611240
10Locked37.611320
11Locked38.65250
12Locked37.317870
13Locked37.611570
14Locked37.63980
15Locked37.3513389
16Locked37.6337328
17Locked38.64200
18Locked37.61640
19Locked37.31020
20Locked37.3800
21Locked37.6760
22Locked38.9790
23Locked38.61130
24Locked38.6340
1462000005.1512064 qam3
2258000005.1512064 qam6
3326000005.1512064 qam5
4393999835.1512064 qam4
3ATDMA0000
4ATDMA0000
Tags (2)
Anonymous
Not applicable
Message 2 of 10
Re: Speed very slow intermittently
Upstream power levels too high:
These values are actually 51 as the HUB 3 reports a decimal out.
Your downstream power levels are quite low as well, however in spec (-6 to +10).
You need VM to investigate further.
  • 22.35K
  • 2.4K
  • 3.99K
Message 3 of 10
RS error counts might be a worry - to check it out can you reboot the Hub and check they reset to 0. Then see if they start reappearing in the next few hours/days - they shouldn't - particularly the postRS ones.
See if anything else changes - and post up your network logs as well.
pda1984
  • 8
Message 4 of 10
rebooted at 11pm yesterday and the RS count seems to be climbing back up quickly
2235000000-4.438256 qam13
8283000000-4.238256 qam19
9291000000-438256 qam20
11307000000-3.538256 qam22
14371000000-4.237256 qam26
15379000000-4.437256 qam27
16387000000-4.537256 qam28
17395000000-4.238256 qam29
18403000000-4.437256 qam30
19411000000-4.537256 qam31
20419000000-4.238256 qam32
21427000000-4.238256 qam33
22435000000-4.238256 qam34
23443000000-4.538256 qam35
24451000000-4.738256 qam36
1Locked37.61330
2Locked38.6290
3Locked38.6970
4Locked38.6200
5Locked38.6130
6Locked37.6230
7Locked38.6620
8Locked38.6390
9Locked38.6220
10Locked37.640
11Locked38.6210
12Locked37.61020
13Locked37.31210
14Locked37.6100
15Locked37.380
16Locked37.6190
17Locked38.6100
18Locked37.380
19Locked37.680
20Locked38.690
21Locked38.660
22Locked38.9180
23Locked38.9170
24Locked38.620
  • 22.35K
  • 2.4K
  • 3.99K
Message 5 of 10
Mmm... the errors are getting corrected ok though (PostRS=0). But if your up power levels are still at the top of the range (51) it will need looking at by someone from VM.
You didnt say whether yu get "drop outs" or is it just speed issues?
In the meantime try this
First do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any splitters/attenuators/etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box.
Then do a Hub “pinhole reset” a lot of VM techs will ask you to try it first - disconnect any ethernet cables and with the Hub "switched on" throughout, press pin in firmly with paper clip/SIM tray tool (or similar) and hold it there firmly for 60 seconds – release the pin then leave it 10’ to stabilise. But, make sure the 2 passwords on the Hub sticker are still there and legible first !
Also, in the meantime, if you haven’t already, its worth setting up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” when you have the first 24h period.
-tony-
  • 16.52K
  • 1.31K
  • 3.9K
Message 6 of 10
hmmmmm as above - keep your eyes on the pre rs errors but the few you have could be nothing - the line/hub will see a few on boot up - if they do not rise they they should not be a worry
i dont disagree with the comment about upstream levels being high/max at 5.1 [51] but VM might - they have been recently saying 5.2 [52] is ok but only when there are no problems
the network log might fill in some info - post that
____________________
Tony
pda1984
  • 8
Message 7 of 10
Hi, it's been a week and the RS errors have jumped fairly high.
1331000000-4.237256 qam25
3243000000-4.438256 qam14
4251000000-4.538256 qam15
5259000000-4.438256 qam16
6267000000-438256 qam17
7275000000-3.938256 qam18
9291000000-3.738256 qam20
10299000000-3.537256 qam21
11307000000-3.238256 qam22
12315000000-3.737256 qam23
13323000000-4.237256 qam24
14371000000-437256 qam26
15379000000-4.237256 qam27
16387000000-4.237256 qam28
17395000000-438256 qam29
18403000000-4.237256 qam30
19411000000-4.237256 qam31
21427000000-438256 qam33
22435000000-438256 qam34
23443000000-4.438256 qam35
24451000000-4.538256 qam36
1Locked37.611250
2Locked38.67942
3Locked38.619742
4Locked38.62960
5Locked38.61880
6Locked38.64921
7Locked38.913670
8Locked38.67560
9Locked38.61560
10Locked37.61600
11Locked38.95100
12Locked37.617330
13Locked37.618450
14Locked37.3780
15Locked37.698476
16Locked37.64716724
17Locked38.61860
18Locked37.61350
19Locked37.6650
20Locked38.61010
21Locked38.61370
22Locked38.61040
23Locked38.6750
24Locked38.6490
14/08/2020 23:40:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/08/2020 15:22:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/08/2020 14:58:34noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/08/2020 14:58:34ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/08/2020 00:13:16ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 09:44:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 09:27:59ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 14:19:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 10:58:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 17:37:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 07:07:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 17:57:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 14:57:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/08/2020 10:37:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/08/2020 21:12:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/08/2020 14:58:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/08/2020 10:58:46ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2020 21:39:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2020 17:49:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/08/2020 14:31:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Beth_G
  • 3.09K
  • 195
  • 301
Message 8 of 10
Hi pda1984,
I'm really sorry for the delayed response to you, and to hear of the broadband issues you've been suffering from.
I've had a quick look at the back end of your services and I can't see any real problems with your hub specs. Everything is how we'd expect.
Let me know how your connection has been this week - if you're still experiencing problems, give me a shout and we'll go from there 🙂
Many thanks,
Beth
pda1984
  • 8
Message 9 of 10
Hi Beth,
Can or someone please have another look my connection the last couple of weeks has been terrible.
Every day there is an error in the log for something, I'm also getting very high post rs errors
1 387000000 -4.2 37 256 qam 28
2 235000000 -4.7 38 256 qam 13
3 243000000 -4.7 38 256 qam 14
4 251000000 -4.7 38 256 qam 15
5 259000000 -4.5 37 256 qam 16
6 267000000 -4.2 38 256 qam 17
7 275000000 -3.7 38 256 qam 18
8 283000000 -3.9 38 256 qam 19
9 291000000 -3.5 38 256 qam 20
10 299000000 -3.4 37 256 qam 21
11 307000000 -3 38 256 qam 22
12 315000000 -3.4 37 256 qam 23
13 323000000 -4 37 256 qam 24
14 331000000 -4 37 256 qam 25
15 371000000 -4 38 256 qam 26
16 379000000 -4.2 37 256 qam 27
17 395000000 -4 38 256 qam 29
18 403000000 -4.2 37 256 qam 30
19 411000000 -4.5 37 256 qam 31
20 419000000 -4.5 38 256 qam 32
21 427000000 -4.4 38 256 qam 33
22 435000000 -4.5 38 256 qam 34
23 443000000 -4.7 38 256 qam 35
24 451000000 -4.7 38 256 qam 36
1 Locked 37.6 2625 5724
2 Locked 38.6 13482 1420
3 Locked 38.6 12633 1191
4 Locked 38.6 4888 848
5 Locked 37.6 3848 142
6 Locked 38.6 2545 56
7 Locked 38.6 2649 35
8 Locked 38.6 2238 97
9 Locked 38.6 1736 35
10 Locked 37.6 1873 22
11 Locked 38.6 2340 56
12 Locked 37.6 2340 81
13 Locked 37.6 2775 52
14 Locked 37.6 1782 18
15 Locked 38.6 1576 16
16 Locked 37.3 1911 333
17 Locked 38.6 2219 229
18 Locked 37.6 1819 20
19 Locked 37.3 1630 46
20 Locked 38.6 1843 23
21 Locked 38.6 1478 3
22 Locked 38.6 1404 6
23 Locked 38.9 1472 12
24 Locked 38.6 1498 16
1 25800000 51 5120 64 qam 6
2 32600000 51 5120 64 qam 5
3 39400000 51 5120 64 qam 4
4 46200000 51 5120 64 qam 3
1 ATDMA 0 0 2 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 1 0
4 ATDMA 0 0 3 0
16/10/2020 20:07:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 11:49:28 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 11:49:28 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 21:01:17 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 17:08:48 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 00:11:10 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 08:16:46 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 08:16:46 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/10/2020 22:25:55 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/10/2020 10:27:37 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/10/2020 08:39:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/10/2020 09:14:5 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/10/2020 03:31:1 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2020 19:45:54 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2020 14:07:40 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Steven_L
  • 4.62K
  • 338
  • 458
Message 10 of 10
Hey @pda1984,
Sorry to hear that you've been having issues with you broadband connection. How is your connection running at the moment?
I have been able to look into your account from your community profile information and can see that your upstream levels are on the high side but our system shows this as still in the acceptable levels for a good connection.
Also, please could you set up a BQM monitor using this link here as it well help us track any issues that you maybe having and help us diagnose any issues that you may still be having.
Steven_L
