annisonj
  • 16
Message 1 of 34
Speed upgraded
I upgraded mid December  to the M500 broadband speed but have had lower than my old M350 since. Tried hard wired direct from router and the most from that is around 200.
Ideas??
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 34
Re: Speed upgraded
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 34
Re: Speed upgraded
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
annisonj
  • 16
Message 4 of 34
Re: Speed upgraded
1202750000-0.738256 qam9
2210750000-0.738256 qam10
3218750000-0.538256 qam11
4226750000-0.540256 qam12
5234750000-0.438256 qam13
6242750000-0.538256 qam14
7250750000-0.438256 qam15
8258750000-0.540256 qam16
9266750000-0.538256 qam17
10274750000-0.738256 qam18
11282750000-0.538256 qam19
12290750000-0.538256 qam20
132987500000.238256 qam21
143067500000.538256 qam22
153147500000.740256 qam23
16322750000140256 qam24
173307500001.240256 qam25
18370750000240256 qam26
193787500002.240256 qam27
20386750000240256 qam28
21394750000240256 qam29
22402750000240256 qam30
234107500001.938256 qam31
244187500001.540256 qam32
1Locked38.96750
2Locked38.96940
3Locked38.97650
4Locked40.36720
5Locked38.97050
6Locked38.66890
7Locked38.96730
8Locked40.36120
9Locked38.96180
10Locked38.96490
11Locked40.36470
12Locked38.96970
13Locked38.97000
14Locked38.97310
15Locked40.36900
16Locked40.36990
17Locked40.96560
18Locked40.36080
19Locked40.36220
20Locked40.36370
21Locked40.96700
22Locked40.36770
23Locked38.96990
24Locked40.37021
13260000046512064 qam4
24620002446.3512064 qam2
35370000046.3512064 qam1
43939999046512064 qam3
1ATDMA0070
2ATDMA0020
3ATDMA0000
4ATDMA000
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID77574
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID77573
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
annisonj
  • 16
Message 5 of 34
Re: Speed upgraded
Corey_C
  • 4.77K
  • 242
  • 397
Message 6 of 34
Re: Speed upgraded
Thanks for your post and welcome to the Community Forums, annisonj,
Apologies for the delayed response, are you still having speed issues, I've run a remote diagnostic and not currently detecting any issues.
Cheers,
Corey C
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 34
Re: Speed upgraded
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
annisonj
  • 16
Message 8 of 34
Re: Speed upgraded
91mb
annisonj
  • 16
Message 9 of 34
Re: Speed upgraded
So - according to your checks i should be getting 500mb...?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 34
Re: Speed upgraded
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
