  • 10
crumble1984
Message 1 of 10
Speed too slow on vivid 350
I have just upgraded to vivid 350 but getting speeds of around 80mb on average. We have the hub in modem mode and connected to an Asus router, there are 10-12 devices connected to it most of the time but only about 2 or 3 actually being used at any one point. I have tried disconnecting the majority of the devices but still not getting the higher speed that we are paying for. What can i do to get the correct speed?
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 2 of 10
Re: Speed too slow on vivid 350
How are you connecting wired or wirelessly?
If wireless, try wired directly to the hub with a Cat 5e cable or better with a device equipped with a gigabit ethernet network card.
  • 10
crumble1984
Message 3 of 10
Everything apart from 1 tivo box is connected through wireless, the computer i use is not near the hub so i can't have a wired connection to it.
  • 3.03K
  • 157
  • 464
jpeg1
Wise owl
Message 4 of 10
The "correct speed" is the speed VM send to the Hub, and which you should get with a wired connection to the Hub.
WiFi speeds are affected by many local factors.
  • 12.94K
  • 513
  • 1.18K
Message 5 of 10
What Asus router model do you have?
wireless speed can depend on the adapter you got to get better speed.
  • 10
crumble1984
Message 6 of 10
I have an ASUS RT-N66U router and the adapter on my computer is a ASUS USB N66.
  • 4.99K
  • 350
  • 850
Roger_Gooner
Superstar
Message 7 of 10
Even when you get full download speeds, you don't want to be held back by your old wireless-N router, get a wireless-AC
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 11.8K
  • 1.08K
  • 2.56K
griffin
Message 8 of 10
You will need to upgrade the adapter as well as the ASUS USB N66 adapter is not capable of 350Mbps.
However, it should be capable of around 250Mbps on the 5 GHz band depending on your wireless environment and settings.
  • 10
crumble1984
Message 9 of 10
Any suggestions?
  • 10.76K
  • 1.1K
  • 1.72K
Message 10 of 10
Whats your budget and requirements in a new router ?
