on 20-07-2022 09:23
My broadband download speed has dropped from 500-550Mbps to 35-45Mbps over the past two days. The speed test looks like the speed is being throttled at a low rate. Any known issues causing this?
on 20-07-2022 13:41
on 20-07-2022 17:08
Thanks John. Connection for speed test is via Ethernet and has always been reliable. Download speed is throttled consistently to 45Mbps down and 10Mbps up on the 500Mbps plan which usually gives around 550Mbps. This speed drop has been consistently the same for the past 3 days. I’ve checked using all methods and no service difficulty has been reported.
on 20-07-2022 19:01
on 20-07-2022 22:23
Thanks John. I have it connected to an Orbi router and nothing has changed. The speed test is done via the Orbi router connected via Ethernet. It strikes me as odd that the upload is suddenly 10Mbps consistently and download always 45Mbps consistently. I regularly test the speed and it’s always been good. Nothing has changed. I doubt if I’ll invest in a new Ethernet cable and do all of the steps you’ve mentioned due to time etc. I’ll let you know if and when the speed returns to normal!
on 21-07-2022 13:21
on 22-07-2022 07:18
Thanks John that seems highly unlikely but it’s been 4 days now at constantly the same up and down speed so will test and report back.
on 22-07-2022 07:45
I’ve now tested as per your instructions using a new Ethernet cable, modem mode with no other connections and I get exactly the same result as the Orbi router speed test; 45 down and 10 up. Can someone at virgin do something about it?
Andy
on 22-07-2022 10:10
Hi John,
Nothing has changed my end but speed has now returned back to normal. Was any cause found?
Andy
on 22-07-2022 14:14
