nigelscoffield2
  • 58
Message 1 of 25
Speed test
Paying for 110 connection ( fibre). 
Anonymous
Not applicable
Message 2 of 25
Re: Speed test
nigelscoffield2
  • 58
Message 3 of 25
Re: Speed test
 not working
Anonymous
Not applicable
Message 4 of 25
Re: Speed test
Are you using a vpn? Is the hub in modem mode?
nigelscoffield2
  • 58
Message 5 of 25
Re: Speed test
No vpn
  • 15.84K
  • 2.1K
  • 4.97K
Message 6 of 25
Re: Speed test
Hi @nigelscoffield2
The sam knows realspeed test doesn't work on the M100 connections
You can use this link instead https://speedtest.samknows.com/
I find the Ookla app  is more reliable for your PC than the web based test
https://www.speedtest.net/apps/windows
Dave
Love, love and love, forever - Pele
nigelscoffield2
  • 58
Message 7 of 25
Re: Speed test
  • 6.79K
  • 591
  • 1.78K
Message 8 of 25
Re: Speed test
Wired or wireless?  VM do not guarantee WiFi speeds. You need to test with a direct wired connection to the Hub.
  • 20.47K
  • 828
  • 2.2K
Message 9 of 25
Re: Speed test
yup you need to test by wire if by wireless and you think you can do better get your own wifi router with 1Gb ports and use hub in modem mode.
nigelscoffield2
  • 58
Message 10 of 25
Re: Speed test
As you can see we usually get much higher speeds but has dropped recently ,
WiFi or not.
