P1MHL
  • 9
Message 1 of 7
Speed suddenly halved since Monday morning
Hi All,
Having previously had a lot of issues that were finally confirmed as line/engineering problems I keep a close eye on speed etc. All ways checking on an ethernet connection.
Got a 200mb package and since the problems were fixed about 4 months ago get consistent 108 to 215 download and 19 to 20 upload speeds. Same reading first thing Monday then dropped to 75 to 80 download, but with a consistent 20 upload.
Restarted hub (with a 5 minute wait) but no change. Hub stats all look OK with no issues. It is as if I've just been switched to a slower speed.
South East London DA5 area. No issues reported by VM in the area.
Anyone else found similar or know what is going on?
Mark
conman33158
  • 1.55K
  • 131
  • 295
Super solver
Message 2 of 7
Re: Speed suddenly halved since Monday morning
Have you tried a full factory reset? Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection.
Please ensure that your WiFi network password is still readable on the Hub sticker before you do this or that you at least have a copy of your original network password.
Can you please upload your router stats and set up a BQM
Type 192.168.0.1 or (192.168.100.1 if you have your Hub in Modem mode) into your address bar at the top of your browser
Do NOT log in, just click “Check Router Status” at the bottom of the page. Sometimes the “Check Router Status” is missing, in this case just go ahead and log in and go to Advanced Settings-> Tools-> Network Status.
Please copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs, if you get a yellow warning just click the Post button again.
Do not try to fit everything in one post! You can use more than one post for each item if needed!
If you get a warning when you hit “Post” just hit “Post” again and it should work ok!
Please do not use screenshots
Also can you please setup a Broadband Quality Monitor (BQM) at thinkbroadband.com. Just click on Create a new monitor.
Under your graph you just created Click (Share Live Graph)
Copy the text in the “Direct Link” box and paste it on here
P1MHL
  • 9
Message 3 of 7
As requested the stats from the HUB
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
202750000
2.9
38
256 qam
9
2
210750000
2.7
37
256 qam
10
3
218750000
2.7
38
256 qam
11
4
226750000
2.5
38
256 qam
12
5
234750000
2.5
38
256 qam
13
6
242750000
2.4
38
256 qam
14
7
250750000
2.2
38
256 qam
15
8
258750000
2.4
38
256 qam
16
9
266750000
2.4
38
256 qam
17
10
274750000
2.2
38
256 qam
18
11
282750000
2.4
38
256 qam
19
12
290750000
2.5
38
256 qam
20
13
298750000
2.5
38
256 qam
21
14
306750000
2.7
38
256 qam
22
15
314750000
2.7
38
256 qam
23
16
322750000
2.9
38
256 qam
24
17
330750000
2.7
38
256 qam
25
18
338750000
2.9
38
256 qam
26
19
346750000
2.7
38
256 qam
27
20
354750000
2.7
38
256 qam
28
21
362750000
2.9
38
256 qam
29
22
370750000
3
38
256 qam
30
23
378750000
3.2
38
256 qam
31
24
386750000
3
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
36
0
2
Locked
37.6
17
0
3
Locked
38.6
12
0
4
Locked
38.6
21
0
5
Locked
38.9
27
0
6
Locked
38.9
41
0
7
Locked
38.6
30
0
8
Locked
38.6
17
0
9
Locked
38.6
13
0
10
Locked
38.6
15
0
11
Locked
38.6
15
0
12
Locked
38.6
25
0
13
Locked
38.6
23
0
14
Locked
38.6
22
0
15
Locked
38.6
28
0
16
Locked
38.6
26
0
17
Locked
38.6
34
0
18
Locked
38.6
17
0
19
Locked
38.6
14
0
20
Locked
38.6
25
0
21
Locked
38.9
21
0
22
Locked
38.9
12
0
23
Locked
38.9
16
0
24
Locked
38.6
27
0
P1MHL
  • 9
Message 4 of 7
More stats
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
48.5
5120
64 qam
1
2
32600000
48
5120
64 qam
3
3
25800053
47.8
5120
64 qam
4
4
39400000
48.3
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
4
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
2
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID
75768
Max Traffic Rate
230000061
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
75767
Max Traffic Rate
22000061
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Time
Priority
Description
14/06/2021 09:15:35
critical
No Ranging Response received - T3 time-out;CM-MAC= XXXXXXXXXX;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 06:18:21
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC= XXXXXXXXXX;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 06:18:18
Warning!
Lost MDD Timeout;CM-MAC= XXXXXXXXXX;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 06:18:14
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC= XXXXXXXXXX;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 06:18:14
Warning!
RCS Partial Service;CM-MAC= XXXXXXXXXX;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 06:18:14
critical
14/06/2021 06:18:13
Warning!
12/06/2021 03:23:51
critical
11/06/2021 12:21:5
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC= XXXXXXXXXX;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
08/06/2021 05:28:21
critical
08/06/2021 00:21:4
Error
04/06/2021 12:57:46
critical
04/06/2021 12:21:3
Error
01/06/2021 23:34:50
critical
01/06/2021 18:57:23
Error
27/05/2021 21:37:33
critical
27/05/2021 16:44:49
Error
24/05/2021 23:08:0
critical
24/05/2021 04:44:48
Error
20/05/2021 20:12:55
critical
P1MHL
  • 9
Message 5 of 7
OK an update.
I ran a speed test on my phone using wifi and got a faster speed than the ethernet connection on my PC!
Checked again all ethernet connections were sound and found no problems and no improvements.
Restarted the Hub again with everything disconnected and then reconnected the ethernet cables one at a time once the Hub was back up and running.
Speeds are now testing as normal again, 212 download and 21 upload.
Happy, but none the wiser as to what the problem was.
conman33158
  • 1.55K
  • 131
  • 295
Super solver
Message 6 of 7
Glad you're sorted again mate, your stats all look fine. Just for future reference make sure the Ethernet cables a Cat5e or better or if it happens again try swapping them out to see if it makes any difference 🙂
Akua_A
  • 1.23K
  • 31
  • 79
Message 7 of 7
Hi @P1MHL,
Welcome back to our community forums.
Sorry to hear you experienced this issue with your broadband speeds. We can understand the inconvenience caused during this time. We are however glad to hear the issue was resolved.
Please continue to monitor the service and let us know if the issue occurs again.
Many thanks,
Akua_A
