Glasgow_Adam
Speed stuck ~270Mbps
Hi all
ive been on 500Mbps with a Hub 3 and now 1Gbps with a Hub 4 and my speed has never gone past around 270Mbps with the odd exception after a reboot where it’ll go over 300. It’s impossible to get hold of the right person to help out through chat or phone - can anyone help?
Adam
Tags (1)
Anonymous
Not applicable
Re: Speed stuck ~270Mbps
if that is wireless that is a good wireless speed
Glasgow_Adam
When it was installed and every now and again after a factory reset I can get over 500Mpbs on wireless so the speed is really poor
also that speed is to the internet from router not from phone to router
Anonymous
Not applicable
wireless can't be garanteed. test your speed with a wired connection on a device with a gigabit network card
Glasgow_Adam
Plugged in directly to router and I still get the same speeds as on wireless
Anonymous
Not applicable
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
We can have a look for any oddities in the stats.
So we can get a better picture of your connection over time can you create a BQM (Broadband Quality Monitor) here, and post the 'live' graph in here?
