Grumpywhale
  • 15
Speed some 10% of what it should be
Whilst i understand we are in unprecedented times for usage as we all work at home, i should have 1gb down and 50 up but im averaging only 110 down 40 up. Now this is usable but why should i be paying for the higher speed when i cant and dont actually get it. Are there issues in my area and how do we even contact at the minute as the call centre is so busy and chat is switched off
DJ_Shadow1966
  • 6.65K
  • 1.28K
  • 1.81K
Re: Speed some 10% of what it should be
Hello
What does the internal speed test show at https://samknows.com/realspeed/ ?
Regards Mike
C_Butcher86
  • 564
  • 190
  • 164
Give your hub a pin hole reset for at least 30 seconds then leave the hub 10 mins to update, this should solve your issue.
Thanks Chris
To PM just hover over my profile picture and click Send Message when the option comes up. Please don't post any of the info I've asked for in this thread as it's public
Stumac1980
  • 130
  • 25
  • 25
Please PM me with your account number and area reference and I can take a look at this for you.
Stuart
I am a Virgin Field Technician. All and any advice given is based on my experience in the field or my personal experiences with my own set up at home. If my answer was helpful to you please mark as helpful or consider leaving the post some kudos.
Grumpywhale
  • 15
  • How do I pm from here?
dannylau
  • 11.02K
  • 891
  • 2.45K
click on their picture then click the send message option
