MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 1 of 7
Speed reducing
Over the last couple of weeks I have noticed that my broadband speed has reduced from around 540Mbs to about 375Mbs.
The speed is constant day / evening / night / weekend, so I don't think it is a contention problem.
Hub 3 in Modem Mode with Netgear R8000P router.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
14190000002.738256 qam30
21870000001.738256 qam7
3195000000238256 qam8
42030000002.240256 qam9
52110000002.238256 qam10
62190000002.438256 qam11
72270000002.540256 qam12
82350000002.438256 qam13
92430000002.538256 qam14
102510000002.238256 qam15
112590000002.238256 qam16
122670000002.538256 qam17
132750000002.238256 qam18
142830000002.238256 qam19
152910000002.238256 qam20
162990000002.738256 qam21
173070000002.738256 qam22
183150000002.938256 qam23
193230000002.738256 qam24
20379000000338256 qam25
21387000000338256 qam26
223950000003.238256 qam27
234030000002.938256 qam28
244110000002.737256 qam29
1Locked38.969250
2Locked38.915050
3Locked38.911940
4Locked40.310660
5Locked38.99540
6Locked38.67750
7Locked40.35850
8Locked38.97420
9Locked38.96270
10Locked38.98650
11Locked38.68940
12Locked38.910310
13Locked38.910240
14Locked38.911450
15Locked38.611460
16Locked38.913600
17Locked38.910350
18Locked38.613220
19Locked38.613460
20Locked38.631130
21Locked38.638550
22Locked38.645670
23Locked38.662870
24Locked37.677920
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: Speed reducing
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1394000044.95512064 qam6
2258000044.95512064 qam8
3325999744.95512064 qam7
4462000535.1512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
The Power (dBmV)never goes below 4.95 and is often up at 5.1 on one or more channels.
Network LogTime Priority Description
10/05/2020 06:53:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 13:52:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 13:52:12criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 13:50:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 13:50:52criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 13:49:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 13:49:32criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/05/2020 01:23:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/05/2020 09:57:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2020 19:30:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2020 14:07:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 14:57:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2020 09:48:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 19:48:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 09:21:45noticeDHCP Renew - lease parameters tftp file-Vcb573b2ee9a9587e.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 09:21:45ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 09:10:28ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2020 08:26:35noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2020 11:07:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2020 15:40:1noticeDHCP Renew - lease parameters tftp file-Vcb573b2ee9a9587e.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 7
Re: Speed reducing
Forgot to mention.
Speed is with a network cable connection.
I have replaced the network cables.
Speed is the same in Modem Mode directly connected to the Hub 3 or going through the Netgear Router.
gary_dexter
  • 30.44K
  • 1.88K
  • 4.04K
Message 4 of 7
Re: Speed reducing
Your upstream levels are too high there
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 7
Re: Speed reducing
I have spoken to at least 3 VM Techies about the Upstream levels and each one has stated that VM won't action any remedial work until they go above the 5.1 level.
The levels at present ...
1394000045.1512064 qam6
2258000045.1512064 qam8
3325999745.1512064 qam7
5
josh94
  • 29
Message 6 of 7
Re: Speed reducing
Just about to post a thread about this...... I actually put my post code in the checker... and it says good news!! you can get M350.... erm... im paying the max oomph 99£ a month bundle for 500... I haven't seen anything past 400 in what seems like WEEKS... Weird huh? Same setup as you but i am using Ubiquiti gear
gary_dexter
  • 30.44K
  • 1.88K
  • 4.04K
Message 7 of 7
Re: Speed reducing
Not relevant at all.
Please keep to your own post.
