Speed rediculously slow
supposed to be on 200mb package, but the last few days i am getting a max speed of 1.2mbs.  i have done everything Virgin have advised on their website including turning off and factory resetting the router.  playstation is connected via LAN cable and has same speeds.  the kids are all connected via wireless and ALL day long i am hearing "DAAAAAD THE INTERNETS OFF AGAIN"  For the sake of my sanity........someone.......anyone....please help
  • 20.96K
  • 1.13K
  • 2.7K
Re: Speed rediculously slow
You need to be speed testing with a wired device that isn’t a console to get any accurate speeds
PC via LANRe: Speed rediculously slow
ok so done that.  plugged PC into LAN.  Speedtest.net recomended by Virgin will not connect to start test.  Offcom speed checker getting 0.7 MBS on their checker.  edit. speedchecker.net conected
  • 20.96K
  • 1.13K
  • 2.7K
Re: PC via LANRe: Speed rediculously slow
Is that direct to the hub and not via a switch or powerline plug etc?
direct to hub. managed to get through to customer support and once every single wifi device was turned off, wondows booted into safe mode, factory reset hub, he managed to get speed back to about 118MBS. as soon as he went off the phone we dropped back down to 0.13MBS even on the LAN PC
  • 605
  • 36
  • 93
Rising star
OK, time to do some of your own diagnostics.
Does the speed vary much at different times of the day - particularly past midnight compared with 7pm?
Get some stats data from the hub. Point your browser to 192.168.0.1 - you won't need to login if you have in the past.
If you have a SH3 the use the link at the bottom of the page and post the upstream, downstream and network log.
Really doesn't matter how you test speeds if you are seeing rates that low.
Do you have times when the Internet disconnects completely?
