on 01-07-2022 16:49
I recently had an engineer visit who could not find / fix this issue. I have a Hub 4 in modem mode connected to a debian firewall. Until recently I have seen consistent speeds > 300mb on my 350mb package. As of a few days ago my speed seems to be stuck at around 40mb downstream (upstream remains consistently around 40mb as it always has).
Things I have tried:
1. Reboot hub 4. After a reboot, I do see fast speeds for a short amount of time - sometimes 5 minutes, sometimes 30, but they always then do come down to around 40mb which is where they stay.
2. Plug a laptop directly into Hub 4 using a different ethernet cable. Same symptoms as above.
3. Reboot / patch / restart my own firewall - no difference.
Anybody have any idea what I can try next? Connection stats follow...
on 01-07-2022 16:50
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 4 |
DOCSIS 3.1 channels | 1 | 0 |
on 01-07-2022 16:51
37 | 426750000 | 6.3 | 39 | QAM256 | 37 |
32 | 386750000 | 5.9 | 39 | QAM256 | 32 |
33 | 394750000 | 5.9 | 39 | QAM256 | 33 |
34 | 402750000 | 6.2 | 39 | QAM256 | 34 |
35 | 410750000 | 6.2 | 40.4 | QAM256 | 35 |
36 | 418750000 | 6.4 | 39 | QAM256 | 36 |
0 | 0 | 0 | QAM256 | 0 | |
39 | 442750000 | 6.3 | 40.4 | QAM256 | 39 |
40 | 450750000 | 6.1 | 39 | QAM256 | 40 |
10 | 210750000 | 6.3 | 40.4 | QAM256 | 10 |
11 | 218750000 | 5.9 | 40.9 | QAM256 | 11 |
12 | 226750000 | 5.6 | 40.4 | QAM256 | 12 |
13 | 234750000 | 5.2 | 40.4 | QAM256 | 13 |
14 | 242750000 | 5.5 | 39 | QAM256 | 14 |
15 | 250750000 | 6.4 | 39 | QAM256 | 15 |
16 | 258750000 | 7.4 | 40.4 | QAM256 | 16 |
17 | 266750000 | 7.9 | 40.9 | QAM256 | 17 |
18 | 274750000 | 8.1 | 40.4 | QAM256 | 18 |
19 | 282750000 | 8.3 | 40.9 | QAM256 | 19 |
20 | 290750000 | 8.3 | 40.4 | QAM256 | 20 |
21 | 298750000 | 7.9 | 40.9 | QAM256 | 21 |
22 | 306750000 | 8 | 40.9 | QAM256 | 22 |
23 | 314750000 | 7.9 | 40.9 | QAM256 | 23 |
24 | 322750000 | 7.9 | 40.9 | QAM256 | 24 |
25 | 330750000 | 7.8 | 40.4 | QAM256 | 25 |
26 | 338750000 | 7.9 | 40.9 | QAM256 | 26 |
27 | 346750000 | 7.9 | 40.4 | QAM256 | 27 |
28 | 354750000 | 7.3 | 40.4 | QAM256 | 28 |
29 | 362750000 | 6.6 | 39 | QAM256 | 29 |
30 | 370750000 | 5.8 | 39 | QAM256 | 30 |
31 | 378750000 | 5.6 | 40.4 | QAM256 | 31 |
37 | Locked | 38.983261 | 0 | 0 |
32 | Locked | 38.983261 | 0 | 0 |
33 | Locked | 38.983261 | 0 | 0 |
34 | Locked | 38.983261 | 0 | 0 |
35 | Locked | 40.366287 | 0 | 0 |
36 | Locked | 38.983261 | 0 | 0 |
0 | NotLocked | 0 | 0 | |
39 | Locked | 40.366287 | 0 | 0 |
40 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.946209 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.946209 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.946209 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.946209 | 0 | 0 |
22 | Locked | 40.946209 | 0 | 0 |
23 | Locked | 40.946209 | 0 | 0 |
24 | Locked | 40.946209 | 0 | 0 |
25 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.946209 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
159 | 96 | 4K | 1840 | QAM4096 | 759 |
159 | Locked | 41 | 4.2 | 475385714 | 0 |
on 01-07-2022 16:51
1 | 53700000 | 47 | 5120 KSym/sec | QAM64 | 10 |
2 | 32600000 | 45.3 | 5120 KSym/sec | QAM64 | 13 |
3 | 39400000 | 45.8 | 5120 KSym/sec | QAM64 | 12 |
4 | 46200000 | 46.3 | 5120 KSym/sec | QAM64 | 11 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 01-07-2022 16:52
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | kfoA,.iyewrkldJKDHSUBsgvc |
SFID | 1382 |
Max Traffic Rate | 402500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 1381 |
Max Traffic Rate | 38500089 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
on 01-07-2022 16:52
Fri 01/07/2022 15:41:48 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:41:41 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:41:13 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:41:11 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:38:42 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:38:33 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:38:15 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:38:09 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:37:24 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:37:23 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:37:16 | 6 | CM-STATUS message sent. Event Type Code: 1; Chan ID: 38; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:37:15 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:37:04 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:37:01 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:36:52 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:36:47 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:36:44 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:36:39 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:36:26 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:36:15 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:35:57 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:35:35 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:35:34 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:34:59 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:34:36 | 6 | CM-STATUS message sent. Event Type Code: 1; Chan ID: 38; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:34:35 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:34:27 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:34:17 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:32:53 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:32:37 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:31:32 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:31:15 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:30:08 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:30:03 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:29:33 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:29:25 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:28:57 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:28:45 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:28:31 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:28:27 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:28:21 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:28:13 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:27:43 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:27:39 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:27:19 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:27:07 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:26:56 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:26:47 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:24:36 | 6 | CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 01/07/2022 15:24:35 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 03-07-2022 16:43
Just a polite bump in the hope someone has some idea for what I can try next?
on 04-07-2022 20:25
Bumping a post puts it a the bottom of the queue and is against forum rules. VM answer posts in date/time orders usually within 3 days.
on 06-07-2022 20:54
Good Evening @snakkles, thanks got your post on our Community Forums, and a very warm welcome to you!
Can you please provide us with an update on your services?
I've looked into the local area, and there appears to be no outages effecting the services.
The hub also appears to be in perfect health.
Kindest regards,
David_Bn
on 07-07-2022 08:52
Hi there @David_Bn,
No change here - still sitting around 40mb/s:
No sure what else to try...
