sekhujin
  • 5
Message 1 of 9
Speed often slower than before the 1Gig upgrade
I was originally getting around 360mbps on the virgin m350. Since upgrading to 1Gig, it has dropped to about 200-300 on a good day, and nowhere near the advertised up to speeds of 1Gig. I have tested the speeds over a day (including from 2am - 5am) and the speeds are just as woeful compared to what is being advertised. Though the fact it drops to lower than my previous consistent speeds is worrying. I am using the Superhub 4 as a modem. Even connecting directly to the hub yields the same speeds.
I am copying and pasting my logs and such as advised:
Time
Priority
Description
Thu 01/01/1970 00:01:22
3
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 12/11/2020 11:54:28
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:18
3
Fri 13/11/2020 17:41:01
5
Sun 15/11/2020 18:02:05
5
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 15/11/2020 18:02:22
6
CM-STATUS message sent. Event Type Code: 4; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 17/11/2020 21:53:41
3
Wed 18/11/2020 22:30:37
4
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 20/11/2020 08:26:33
3
Sun 22/11/2020 10:30:38
4
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
sekhujin
  • 5
Message 2 of 9
Re: Speed often slower than before the 1Gig upgrade
SFID
19490
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
19489
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
40.520599
5120 KSym/sec
64QAM
4
2
46200000
40.270599
5120 KSym/sec
64QAM
3
3
60300000
40.520599
5120 KSym/sec
64QAM
1
4
53700000
40.270599
5120 KSym/sec
64QAM
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
3
0
2
US_TYPE_STDMA
0
0
3
0
3
US_TYPE_STDMA
0
0
3
0
4
US_TYPE_STDMA
0
0
3
0
sekhujin
  • 5
Message 3 of 9
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
30
402750000
4.800003
38.983261
QAM256
30
1
138750000
5.099998
36.609653
QAM256
1
2
146750000
4.599998
36.609653
QAM256
2
3
154750000
4.699997
36.609653
QAM256
3
4
162750000
4.599998
36.609653
QAM256
4
5
170750000
4.599998
36.609653
QAM256
5
6
178750000
4.500000
36.609653
QAM256
6
7
186750000
4.400002
37.636276
QAM256
7
8
194750000
4.400002
37.355988
QAM256
8
9
202750000
4.300003
37.355988
QAM256
9
10
210750000
4.400002
37.355988
QAM256
10
11
218750000
4.400002
37.355988
QAM256
11
12
226750000
4.500000
37.355988
QAM256
12
13
234750000
4.699997
37.355988
QAM256
13
14
242750000
4.800003
37.355988
QAM256
14
15
250750000
4.800003
37.355988
QAM256
15
16
258750000
4.699997
37.355988
QAM256
16
17
266750000
4.400002
37.636276
QAM256
17
18
274750000
3.799999
37.636276
QAM256
18
19
282750000
3.599998
37.355988
QAM256
19
20
290750000
4.000000
37.355988
QAM256
20
21
298750000
4.300003
37.355988
QAM256
21
22
306750000
4.599998
37.636276
QAM256
22
23
314750000
4.599998
37.355988
QAM256
23
24
322750000
4.300003
37.636276
QAM256
24
25
330750000
4.199997
37.636276
QAM256
25
26
370750000
4.699997
37.636276
QAM256
26
27
378750000
4.800003
37.355988
QAM256
27
28
386750000
4.800003
37.636276
QAM256
28
29
394750000
4.900002
37.636276
QAM256
29
31
410750000
4.699997
37.636276
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
30
Locked
0
0
0
1
Locked
1776181333
0
0
2
Locked
472982748
0
0
3
Locked
416992285
0
0
4
Locked
297715860
0
0
5
Locked
176317447
0
0
6
Locked
41997479
0
0
7
Locked
4125591531
0
0
8
Locked
2168635357
0
0
9
Locked
2092889112
0
0
10
Locked
2003125512
0
0
11
Locked
1949667216
0
0
12
Locked
1786691636
0
0
13
Locked
1730289832
0
0
14
Locked
1636152943
0
0
15
Locked
1578215789
0
0
16
Locked
2782345887
0
0
17
Locked
2683191046
0
0
18
Locked
4040420728
0
0
19
Locked
3783335756
0
0
20
Locked
2520555469
0
0
21
Locked
2510546541
0
0
22
Locked
2400326164
0
0
23
Locked
2309831647
0
0
24
Locked
2230306364
0
0
25
Locked
2175091119
0
0
26
Locked
2107609095
0
0
27
Locked
2040653727
0
0
28
Locked
1852721185
0
0
29
Locked
1615208577
0
0
31
Locked
1135638111
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
33
86
4K
1680
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
33
Locked
5.2
802554367
0
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 9
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
then
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
sekhujin
  • 5
Message 5 of 9
Hey sorry for the delay in replying. When connected in router mode with no otrher devices connected I waws getting between 400-600mbps. I called Virgin and they said there was a problem, they told me they fixed. After the call I had no Internet for about an hour or two. It was only then that I hard reset the router.
My speeds after that were around the 750 mark, today thbough it'sa round 500-600 😞 . I'm just wondering if that's the best speed I will get? Ididn't see a "connection speed" option? I'm on a superhub4
Also I don't know if it's my router, but whether in router or modem mode, samknows doesn't detect the router
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 9
Sam Knows will not work with the Hub 4 in Modem Mode.
You must be connected directly to the Hub.
sekhujin
  • 5
Message 7 of 9
I also tried in router mode and it errored out. That was directly connected to the router.
Intitially Samknows said my router was offline.
However after it shows my speeds as:
DownloadMbps
1081
Speed to computer
DownloadMbps
912
UploadMbps
52.2
Latencyms
13.3
Jitterms
1.34
Packet loss%
0.0
UploadMbps
52.7
Latencyms
16.8
Jitterms
1.80
Packet loss%
N/A
Could be a dodgy cable then?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 9
DownloadMbps
1081
Speed to computer
DownloadMbps
912
UploadMbps
52.2
Latencyms
13.3
Jitterms
1.34
Packet loss%
0.0
UploadMbps
52.7
Latencyms
16.8
Jitterms
1.80
Packet loss%
N/A
Could very well be, and it is an easy check.
Chris_W1
  • 4.29K
  • 196
  • 273
Message 9 of 9
Hi sekhujin, thanks for the message. We have checked the connection and area outages and is coming up as green. Can you confirm if you are still having issues with this and have tried a different ethernet cable? Chris
