Alibop79
Speed not correct
Just had virgin installed was promised a speed of 500mb only getting 125.so far not a good experience tv doesn't work and speed not as advised. Thank god for a cooling off prieod.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Speed not correct
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
