Nick_Key
  • 6
Message 1 of 13
Speed not as expected
Hello, I recently upgraded from your 100mb broadband (which always gave close to 100mb on speedtest.net) to M200. It was good for a short period but I now only get between 40mb and 70mb.
Ive jumped through the hoops here: https://community.virginmedia.com/t5/Digital-life/Broadband-Speed-Check/ba-p/3459473 to no avail. I have copied the logs from the router but they exceed the 20,000 character max post size!
Many thanks,
jpeg1
  • 7.52K
  • 389
  • 1.47K
Legend
Message 2 of 13
Re: Speed not as expected
What device/s are you measuring the speed with?  Are they connected to the Hub with a good quality ethernet cable?
Nick_Key
  • 6
Message 3 of 13
Hi jpeg1,
Good point - i should have said. Connection being measured on a laptop, connected via decent ethernet cables.
The same main device has been used all the way though, measuring ~100mb on my old deal, then ~200mb, but now only 40-70mb. No wiring or hardware changes have been made. But its the story with other devices in the house. I assumed it was a bad day / fault in the area but its been like this for a couple of weeks now.
  • 35.07K
  • 3.41K
  • 6.67K
Message 4 of 13
Try changing to a new Cat6 ethernet cable. They can and do "fail" and drop back to 10/100 speeds. Also look in the laptop settings and chech that the connection speed has not dropped from 1GB to 100Mbps. Check the drivers are up to date.
Then can you test this way.
_____________________________
As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode”
(https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
This ensures that NO other devices can be connected
Test speeds at https://speedtest.samknows.com/ - try on 2 different browsers.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
Andrew-G
  • 11.16K
  • 1.73K
  • 5.33K
Message 5 of 13
Break the hub status data into three separate posts for Downstream, Upstream and Network log (and if need be, post the network log into two).
There's no harm trying a new ethernet cable, but when that is the problem then normally we see the speed sitting at 85-95 Mbps, as a dodgy cable normally reverts to 100 Mbps protocol, and after the removal of the TCP/IP overheads 94 Mbps is the result.  Have another go posting the data and we can comment for you.
Nick_Key
  • 6
Message 6 of 13
Thank you, will try another cat6 cable and let you know.
Logs:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
234750000
9
38
256 qam
13
2
138750000
11.6
38
256 qam
1
3
146750000
11.5
40
256 qam
2
4
154750000
11.5
40
256 qam
3
5
162750000
11
40
256 qam
4
6
170750000
11
40
256 qam
5
7
178750000
10.9
40
256 qam
6
8
186750000
10.5
38
256 qam
7
9
194750000
10.1
38
256 qam
8
10
202750000
9.9
38
256 qam
9
11
210750000
9.5
38
256 qam
10
12
218750000
9.3
38
256 qam
11
13
226750000
9.1
38
256 qam
12
14
242750000
8.8
38
256 qam
14
15
250750000
8.5
38
256 qam
15
16
258750000
8.5
38
256 qam
16
17
266750000
9
38
256 qam
17
18
274750000
9
38
256 qam
18
19
282750000
9.4
38
256 qam
19
20
290750000
9.4
40
256 qam
20
21
298750000
9.5
38
256 qam
21
22
306750000
9.5
40
256 qam
22
23
314750000
9.8
40
256 qam
23
24
322750000
9.6
40
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
18930
10848
2
Locked
38.9
13479
16122
3
Locked
40.3
10549
18923
4
Locked
40.3
7599
21859
5
Locked
40.3
4629
24757
6
Locked
40.3
3006
26475
7
Locked
40.3
4401
24972
8
Locked
38.6
4265
25223
9
Locked
38.9
6476
22825
10
Locked
38.9
10103
18962
11
Locked
38.9
10861
18200
12
Locked
38.9
16183
14493
13
Locked
38.9
18127
12408
14
Locked
38.9
19271
10760
15
Locked
38.6
19337
11490
16
Locked
38.9
19251
9846
17
Locked
38.6
17498
8614
18
Locked
38.6
16168
10419
19
Locked
38.9
14517
4361
20
Locked
40.3
13987
10720
21
Locked
38.9
12886
3419
22
Locked
40.3
9700
4490
23
Locked
40.3
7954
4730
24
Locked
40.3
7150
4909
Nick_Key
  • 6
Message 7 of 13
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
39
5120
64 qam
1
2
39400000
37.3
5120
64 qam
4
3
46200000
37.5
5120
64 qam
3
4
53700000
38.8
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
10
0
2
ATDMA
0
0
12
0
3
ATDMA
0
0
13
0
4
ATDMA
0
0
17
0
Nick_Key
  • 6
Message 8 of 13
Time
Priority
Description
22/03/2022 09:35:45
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/03/2022 22:49:57
critical
20/03/2022 17:46:0
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/03/2022 17:46:0
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/03/2022 08:35:10
critical
18/03/2022 08:35:10
critical
Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/03/2022 08:01:33
critical
18/03/2022 08:01:33
critical
17/03/2022 08:24:9
critical
17/03/2022 08:24:9
critical
17/03/2022 08:23:30
critical
17/03/2022 08:23:30
critical
17/03/2022 08:23:9
critical
17/03/2022 08:23:9
critical
17/03/2022 08:21:49
critical
17/03/2022 08:21:49
critical
17/03/2022 08:21:29
critical
17/03/2022 08:21:29
critical
17/03/2022 08:20:29
critical
17/03/2022 08:20:29
critical
muffintastic
  • 155
  • 5
  • 11
Up to speed
Message 9 of 13
@Nick_Key wrote:
Time
Priority
Description
22/03/2022 09:35:45
notice
20/03/2022 22:49:57
critical
20/03/2022 17:46:0
notice
20/03/2022 17:46:0
Error
18/03/2022 08:35:10
critical
18/03/2022 08:35:10
critical
18/03/2022 08:01:33
critical
18/03/2022 08:01:33
critical
17/03/2022 08:24:9
critical
17/03/2022 08:24:9
critical
17/03/2022 08:23:30
critical
17/03/2022 08:23:30
critical
17/03/2022 08:23:9
critical
17/03/2022 08:23:9
critical
17/03/2022 08:21:49
critical
17/03/2022 08:21:49
critical
17/03/2022 08:21:29
critical
17/03/2022 08:21:29
critical
17/03/2022 08:20:29
critical
17/03/2022 08:20:29
critical
Have you tried running a service check https://www.virginmedia.com/help/service-status If it says fine then try clicking 'Broadband' then a drop down menu will appear then press 'Test your hub' if that comes back fine then try hard resetting the hub and starting from scratch, this is kind of a last resort measure.
Andrew-G
  • 11.16K
  • 1.73K
  • 5.33K
Message 10 of 13
Amongst several other problems, your downstream power levels are too high.  I've marked for staff to take a look and advise - probably needs a technician visit.
