JustJaneP
  • 26
Message 1 of 42
Speed <1mb, reset only clears temporarily
Hub 3 keeps getting stuck on speed of 1mb for both wired and WiFi connections. Power off/on may briefly clear, full reset clears for few hours or if lucky a few days.
History:. Had occasional problems over last couple of years with old hub that seemed to worsen when Virgin "upgraded" the local area last year sometime. We upgraded to Hub 3 and it's been even worse.
Running the official equipment test never shows a problem. Engineer came out beginning December. Could not find a specific problem but most cables been in for years so he replaced them and cleaned up connections.
Speed was ok for few weeks so Xmas was good !  But we are back to frequent resets tho we tend to just resort to 4g on our phones
Help!!!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 42
Re: Speed <1mb, reset only clears temporarily
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 42
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
JustJaneP
  • 26
Message 4 of 42
Router status
202750000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning
JustJaneP
  • 26
Message 5 of 42
Router status
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12027500004.938256 qam9
2210750000538256 qam10
3218750000538256 qam11
4226750000538256 qam12
5234750000538256 qam13
6242750000538256 qam14
7250750000538256 qam15
82587500005.138256 qam16
92667500005.138256 qam17
102747500005.338256 qam18
112827500005.338256 qam19
122907500005.538256 qam20
132987500005.638256 qam21
143067500005.638256 qam22
153147500005.638256 qam23
16322750000638256 qam24
173307500005.838256 qam25
18370750000638256 qam26
19378750000638256 qam27
203867500006.138256 qam28
21394750000638256 qam29
224027500006.538256 qam30
234107500006.538256 qam31
244187500006.538256 qam32
1Locked38.660
2Locked38.650
3Locked38.960
4Locked38.670
5Locked38.990
6Locked38.950
7Locked38.680
8Locked38.6120
9Locked38.640
10Locked38.900
11Locked38.660
12Locked38.9110
13Locked38.970
14Locked38.980
15Locked38.970
16Locked38.690
17Locked38.980
18Locked38.640
19Locked38.660
20Locked38.670
21Locked38.990
22Locked38.660
23Locked38.9100
24Locked38.670
JustJaneP
  • 26
Message 6 of 42
1 39400000 42.5 5120 64 qam 4
2 46200000 42.5 5120 64 qam 3
3 25800185 42 5120 64 qam 6
4 32600000 42.3 5120 64 qam 5
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
JustJaneP
  • 26
Message 7 of 42
Router status
Status
Downstream
Upstream
Configuration
Refresh data
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID 1724096
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 1724095
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
JustJaneP
  • 26
Message 8 of 42
15/01/2021 10:24:22 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 23:40:12 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 23:14:50 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 12:45:59 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
JustJaneP
  • 26
Message 9 of 42
Sorry read replies in wrong order. Will set up link
JustJaneP
  • 26
Message 10 of 42
My bqm
