LS95
  • 20
Message 1 of 34
Speed keeps dropping
Got virgin installed last monday, speeds were very impressive to what we were use to however every now and then the connection will just die and ill be getting 0.06 mbs download and upload, anyone know what this is about?
Anonymous
Not applicable
Message 2 of 34
Re: Speed keeps dropping
Could you access your router using http://192.168.0.1/ . Don't log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
At least we can check the stats to rule out an issue with the line.
LS95
  • 20
Message 3 of 34
1402750000-1.540256 qam25
2186750000-1.238256 qam7
3194750000-1.538256 qam8
4202750000-1.540256 qam9
5210750000-1.538256 qam10
6218750000-1.740256 qam11
7226750000-1.540256 qam12
8234750000-1.740256 qam13
9242750000-240256 qam14
10250750000-2.240256 qam15
11258750000-2.440256 qam16
12266750000-2.540256 qam17
13274750000-2.740256 qam18
14282750000-2.540256 qam19
15290750000-2.538256 qam20
16298750000-2.438256 qam21
17306750000-240256 qam22
18314750000-1.740256 qam23
19322750000-1.740256 qam24
20410750000-1.538256 qam26
21418750000-1.740256 qam27
22426750000-1.540256 qam28
23434750000-1.738256 qam29
24442750000-1.738256 qam30
1Locked40.3340
2Locked38.9340
3Locked38.9330
4Locked40.3440
5Locked38.9320
6Locked40.3470
7Locked40.3280
8Locked40.3400
9Locked40.3290
10Locked40.3270
11Locked40.3250
12Locked40.3270
13Locked40.3380
14Locked40.9320
15Locked38.9340
16Locked38.9340
17Locked40.3500
18Locked40.3230
19Locked40.3300
20Locked38.9330
21Locked40.3290
22Locked40.3360
23Locked38.9310
24Locked38.9100
LS95
  • 20
Message 4 of 34
1603000003.45512064 qam9
2394000003.5512064 qam12
3462000003.529512064 qam11
4537000003.379512064 qam10
3ATDMA0000
4ATDMA0000
LS95
  • 20
Message 5 of 34
02/08/2020 03:16:32ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 16:45:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 16:28:45noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 18:36:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:19:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:18:49Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:18:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:18:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:17:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:17:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:17:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:17:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:17:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:17:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:17:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/07/2020 16:14:2Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 34
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Anonymous
Not applicable
Message 7 of 34
Your upstream power levels appear to be quite low:
3.5 (Or 35 with the decimal in the correct position!) is considered low from what I've seen in other threads.
  • 23.94K
  • 2.53K
  • 4.34K
Message 8 of 34
This is info from a year or two ago - may have been tweaked !
Downstream: no lower than -6dBmV and no higher than 10dBmV --- Close to 0 is optimal.
Upstream: no lower than 31dBmV and no higher than 51dBmV --- 44dBmV to 46dBmV is optimal.
LS95
  • 20
Message 9 of 34
https://www.thinkbroadband.com/broadband/monitoring/quality/share/2fd97e92831353f675d05a999544ab7ea6d8e244
LS95
  • 20
Message 10 of 34
I dont understand what this means im not very techy
