GavChap
  • 55
  • 5
Speed issues since Friday 19/06/2020
I'm getting around a 10th the speed I should be.
Testing on Windows 10, Chrome browser on speedtest.net connecting to Virgin Media - Luton
I've rebooted the modem a couple of times.
I've got 15 devices on the network, mostly low bandwidth ones like Google Minis and mobile phones.
1483000000-4.240256 qam30
2187000000-138256 qam7
3195000000-1.538256 qam8
4203000000-1.738256 qam9
5211000000-237256 qam10
6227000000-335256 qam12
7235000000-3.538256 qam13
8243000000-3.938256 qam14
9251000000-3.738256 qam15
10259000000-3.438256 qam16
11267000000-340256 qam17
12275000000-2.540256 qam18
13283000000-2.440256 qam19
14291000000-2.238256 qam20
15299000000-238256 qam21
16307000000-240256 qam22
17315000000-240256 qam23
18323000000-1.940256 qam24
19443000000-3.740256 qam25
20451000000-440256 qam26
21459000000-4.240256 qam27
22467000000-4.240256 qam28
23475000000-4.231256 qam29
1Locked40.3569129
2Locked38.925277251151
3Locked38.928791621
4Locked38.652501183
5Locked37.329962357
6Locked3563091382
7Locked38.61371817
8Locked38.91285784
9Locked38.91342551
10Locked38.91777679
11Locked40.31777619
12Locked40.31387415
13Locked40.31607627
14Locked38.61514948
15Locked38.917071068
16Locked40.31686763
17Locked40.31394532
18Locked40.91129423
19Locked40.31040465
20Locked40.9990376
21Locked40.3824227
22Locked40.34201
23Locked3198983494449301
21/06/2020 13:00:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 13:00:5Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:59:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:59:38Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:58:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:58:18Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:56:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:56:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:56:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:56:24Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:56:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:56:8Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:55:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:55:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:55:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:55:44Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:54:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:54:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:54:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 12:54:38noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 22.42K
  • 2.4K
  • 4K
Re: Speed issues since Friday 19/06/2020
Deffo some problems there - are you actually missing down cannel 24 ? 23 is showing v low signal noise ratio and RS error counts off-scale - usually indicates you have noise ingress.
Try this first..
First do a quick check that all of your coax connections are in nice and "finger" tight at the Hub and wall box and at any splitters/attenuators/etc with no “unterminated loose ends – disconnect then and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box.
Then do a Hub “pinhole reset” - with the Hub "switched on" throughout, press pin in firmly and hold it there for 60 seconds – release the pin then leave it 10’ to stabilise. But, make sure the 2 passwords on the Hub sticker are still there and legible first !
If that’s all good.... Post up your stats again - but include the upstream data too.
Also, in the meantime. Set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take an hour or two to start seeing a sensible picture.
GavChap
  • 55
  • 5
It seems fixed. I reconnected all the connection nuts on the modem, splitter and wall unit and it seems to be running ok
Current stats.
2187000000-140256 qam7
3195000000-1.540256 qam8
4203000000-1.940256 qam9
5211000000-240256 qam10
6219000000-2.538256 qam11
7227000000-3.240256 qam12
8235000000-3.540256 qam13
9243000000-440256 qam14
10251000000-3.940256 qam15
11259000000-3.440256 qam16
12267000000-2.940256 qam17
13275000000-2.540256 qam18
14283000000-2.240256 qam19
15291000000-2.240256 qam20
16299000000-240256 qam21
17307000000-2.240256 qam22
18315000000-2.240256 qam23
19323000000-240256 qam24
20443000000-3.740256 qam25
21451000000-3.940256 qam26
22459000000-4.240256 qam27
23467000000-4.240256 qam28
24475000000-4.240256 qam29
1Locked40.960
2Locked40.9190
3Locked40.390
4Locked40.9430
5Locked40.3100
6Locked38.960
7Locked40.330
8Locked40.370
9Locked40.320
10Locked40.910
11Locked40.350
12Locked40.340
13Locked40.980
14Locked40.940
15Locked40.370
16Locked40.360
17Locked40.970
18Locked40.390
19Locked40.910
20Locked40.370
21Locked40.350
22Locked40.3100
23Locked40.380
24Locked40.350
