RP219
Speed issues and packet loss
I currently have the M350 broadband package and have been having lots of issues with Virgin for the past 9 months or so.
Long story short I have had the cable running to the house replaced but have recently started getting slower than normal speeds and 4-6% packet loss in the evening.
It making it difficult to do any online gaming with the packet loss.
I'm plugged into 1gig switch over Cat5e
I've tried calling Virgin but as I work during the day I have to call at night, I just spent over an hour on hold waiting to speak to someone then got cut off.
Any help would be appreciated
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/13e8814fb8b00cd46570018da20103c20af43062"><img alt="My Broadband Ping - VM Home" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/13e8814fb8b00cd46570018da20103c20af43062.png" /></a>
Cable Modem Status
Item Status Comments
202750000
Locked
Ranged Upstream Channel (Hz)
25800204
Locked
Provisioning State
Online
1202750000-238256 qam9
2138750000-1.538256 qam1
3146750000-1.538256 qam2
4154750000-1.738256 qam3
5162750000-1.738256 qam4
6170750000-238256 qam5
7178750000-238256 qam6
8186750000-238256 qam7
9194750000-2.238256 qam8
10210750000-2.238256 qam10
11218750000-2.438256 qam11
12226750000-2.238256 qam12
13234750000-2.538256 qam13
14242750000-338256 qam14
15250750000-2.938256 qam15
16258750000-2.738256 qam16
17266750000-338256 qam17
18274750000-2.938256 qam18
19282750000-2.738256 qam19
20290750000-2.938256 qam20
21298750000-2.738256 qam21
22306750000-2.438256 qam22
23314750000-2.538256 qam23
24322750000-2.438256 qam24
1Locked38.650
2Locked38.960
3Locked38.940
4Locked38.650
5Locked38.950
6Locked38.960
7Locked38.950
8Locked38.960
9Locked38.650
10Locked38.650
11Locked38.950
12Locked38.960
13Locked38.670
14Locked38.630
15Locked38.920
16Locked38.970
17Locked38.620
18Locked38.680
19Locked38.680
20Locked38.660
21Locked38.680
22Locked38.620
23Locked38.970
24Locked38.600
RP219
Re: Speed issues and packet loss
12580020444.5512016 qam4
23260019645512016 qam3
33940004945.5512016 qam2
44620030945.5512016 qam1
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID386756
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID386755
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
19/11/2020 20:51:36ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 17:54:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 16:46:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 18:06:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/11/2020 15:23:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 21:16:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 18:14:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 17:55:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 15:05:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 14:07:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 09:14:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 15:55:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 15:55:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 15:55:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 15:55:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 15:54:33Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 15:54:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
