on 15-01-2022 14:12
Since I change my HUB3 to HUB4 I only been receiving 200 megas, but before I was able to have 350 + megas. My contract is 1 GIG. My desktop is cable connected to the HUB4.
https://samknows.com/realspeed/
on 15-01-2022 15:57
sorry am not hijacking but we are getting the same problem as you ,over the last two days speaking to virgin muppets they said by a virgin IT someone from the other side of the world said its the ethernet lead from the router to pc ,so later i went and got a new one costing me £20 only to find out the problem is still there.again spoke to virgin after going through 4 different people they saying that nothing is wrong on there side and trying to say its my pc hardware, but my pc is brand new build over £3000 worth built over two months ago and up to 4 days ago the speed was ok and in that time nothing have been changed from my side. so good luck to you if you trying to get any info from virgin
on 15-01-2022 17:05
But before I changed to the hub4 I had 350 plus megabytes with the hub3 same desktop and I was in the M350.
Now I'm in GIG1 and using hub4 I'm on 200 megabytes.
I think I have got a faulty hub.
But I don't know if someone can give me any advice on this.
on 18-01-2022 08:55
Hi josecmourao,
So sorry to see you're facing broadband issues.
I can see from looking at your account that you have a technician appointment booked in, let us know how that goes and if it resolves your issue for you.
Also can I ask whether you are using a CAT6 cable to connect your device to your router? Anything lower will not be able to support the 1Gig capabilities of your speed.
