charb
Speed is less than half of what it should be for months now
I'm on the M350 package and to start with I was getting really good speeds, over 400Mbps but now I can't get above 150. I put it down to everyone using the internet but it hasn't improved at all and I've had a few times where my connection has just dropped during zoom calls too which I wouldn't expect with the package I'm on. It looks like only download is affected. Has my speed been capped?Screenshot 2020-08-28 at 12.13.29.png
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Speed is less than half of what it should be for months now
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
