Tareksadoon
Speed is insanely low
i followed the guide and tips on the website but still no luck. I am getting a really slow connection. Would really need an engineer to take a look at it
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Speed is insanely low
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
