Hi.
I am on M350. for the past 2 weeks I have been getting results of between 132.47mbps and 190.12 download when in modem mode. Ping has been between 7-9ms and upload has been 36.29-37.19.
I am on a PC which is a wired connection, Bought a TP-link ax50 on 31st Dec and had the virgin hub in modem mode since. This issue was first noticed and tested on 24th Jan.
I reset my hub and router and I was able to get 342.57mbps (7m ping and 36.57 up). However I noticed that it switched to router mode again (note, my pc is wired to the tp-link router which is wired to the hub)
I assumed it was fixed so swapped back to modem mode and went from 342mbps above to 158mbps. The ping increased by 1ms to 8ms and my upload speed went up to 37.09mbps
At 5am this morning my speeds were 165 down and 37up with a ping of 8ms.
I used www.speedtest.net on chrome, firefox and using the desktop app from the microsoft store. All in the same ballpark.
There has been no changes to anything just we noticed that stuff was taking longer to download than usual that's when it was first noticed and I've been checking speeds often since. Thought I would ask on here if anyone has an idea.
