Speed halved randomly
TheRustyNomad
I’m on the Virgin Volt M250 package and it’s been flawless for about 2 weeks, but today the power tripped and the speed has gone back down to M125… is this normal and how can I get the volt on re-attached?
1 ACCEPTED SOLUTION
Accepted Solutions
I cannot see the image as yet, however I'm going to assume with the HUB 5x you can't see any meaningful stats.
Edit: As I thought they don't display anywhere near as much info as a HFC connection. I assume this is because there are no power levels to report on.
5 REPLIES 5
Check the conf settings on the Hub. It will show what speed has been provisioned.
It's Configuration tab - Primary Downstream Service Flow - Max Traffic Rate.
Sorry, I cannot find that option when I log in. I am on the 5X Hub.
You shouldn't have to login. On the main page there should be a 'Check router status' option under the login box.
From there you access the 'Configuration' tab.
Thanks, it’s sorted now, but I still cannot see the detail about the speeds in my hub:
 Any ideas? Thanks
