Makakar
  • 27
Speed fine, but packet loss/jitter/high pings (Oversubbed?)
Hi All,
Getting great speeds but seem to be getting some packet loss and jitter, usual seems worse at peak times (wired connection, connected to hub in modem mode).
Guessing oversubbed for the area, but not 100% sure.
Link to ThinkBroadband:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d46eab3279255ea299fa0a1d0868d07a9f...
VM Modem stats:
12990000001.236256 qam21
22670000001.436256 qam17
32750000001.436256 qam18
42830000001.236256 qam19
52910000001.236256 qam20
63070000000.936256 qam22
73150000000.936256 qam23
83230000000.936256 qam24
93310000001.236256 qam25
103390000001.236256 qam26
113470000001.536256 qam27
123550000001.236256 qam28
133630000001.236256 qam29
143710000001.236256 qam30
153790000001.236256 qam31
16387000000136256 qam32
173950000000.736256 qam33
184030000000.736256 qam34
194110000000.936256 qam35
204190000000.236256 qam36
214270000000.536256 qam37
22435000000036256 qam38
23443000000-0.436256 qam39
24451000000-0.536256 qam40
1Locked36.360
2Locked36.360
3Locked36.380
4Locked36.350
5Locked36.660
6Locked36.620
7Locked36.650
8Locked36.360
9Locked36.600
10Locked36.360
11Locked36.650
12Locked36.350
13Locked36.670
14Locked36.670
15Locked36.660
16Locked36.690
17Locked36.6150
18Locked36.380
19Locked36.350
20Locked36.3150
21Locked36.6180
22Locked36.320
23Locked36.650
24Locked36.380
1394000003.95512064 qam4
2537000004.025512064 qam2
3603000004.075512064 qam1
4462000003.975512064 qam3
3ATDMA0000
4ATDMA0000
A few "No Ranging Response received" logged, but on different days
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Speed fine, but packet loss/jitter/high pings (Oversubbed?)
Your >> BQM << is a mess and in my opinion it is a problem between you and / or in the street cabinet.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK you need to contact VM.
You can contact VM to report the problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
Makakar
  • 27
Yup, it used to eb and flow with some days being worse than others, but recently it's been getting worse.
Connections are finger tight, had a re-pull of the cable to the property about year and half a ago, could be the short run of the internal though (got loads of spare but no connectors).
I'm happy to wait for VM on here to pick it up in a few days, last time took a while to get past 1st line when it was clear the SNR was way out.
David_Bn
  • 5.4K
  • 247
  • 447
Hi Makakar,
Thanks for your post and I'm sorry to see you've been experiencing issues with your broadband connection.
I've been able to look at the stats of your hub and everything appears to be within spec. I can also confirm that there are currently no issues showing in the local area.
How has the service been since your most recent post on Thursday? Do you have any further BQM graphs to share with us?
Kindest regards,
David_Bn
