faberfaber
Message 1 of 13
Speed dropped since Monday
Hi there,
I am on a 100mbit broadband package which always performed well. On Monday I started experiencing connectivity issues and up on calling virgin media I was told (robot voice) they are doing upgrading works in my area. Would be nice to know that beforehand but oh well....
It's now been 3 days my speed is rarely averaging more than 2mbits which makes it impossible to work. I managed to speak with someone at VM and they are sending me a new router. I told them that I really don't think it'll solve my issue. Anyway I found out this forum and hopefully I will get some clue about what is in front of me. Btw Upload seems fine (around 10mbits)
Here's my router status. It might not be all that is needed, if so apologies.
Many Thanks
12987500007.837256 qam21
1Locked37.6200
1537000313.225512064 qam2
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
vca69834ncxv9873254k;fg87
SFID636
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID635
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 13
Re: Speed dropped since Monday
You only have one Downstream Channel, we would expect to see 24 (Hub 3)
You only have one Upstream Channel, we would expect to see either 2 or 4.
You have quite a problem.
If it is the Hub it will be an easy fix. Don't forget to get the Hub activated when you get it plumbed in.
If it isn't the Hub it will be a Street Cabinet problem that will require an engineer to put right.
Anonymous
Not applicable
Message 3 of 13
Do you really only have one downstream channel (you should have 24) and one upstream (you should have 4)?
PlsFixMyWIFI
Message 4 of 13
OMG my issue is identical to yours!!!!
Speed dropped on Monday to about 1mbps and they keep saying there's an issue in the area which will be fixed by 5pm, well this is going on for 3days in a row now.
Today in the morning I've done all reboots/speed tests/ resets you name it via the online chat with an agent. Then he told me there's an issue in an area and it will be fixed shortly (clearly used it as an excuse to avoid investigating further). Asked him to confirm my router is fine (as I have the newest one with 100Mbps package) which he did. He said there are no visible issues with router.
Received a text around 5pm that the issue in the area is fixed, and well by then my download speed has dropped to less than 1mbps. Absolutely ridiculous. I can hardly load this community page.
Calling them first thing tomorrow morning.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 13
@PlsFixMyWIFI wrote:
... snip ...
If you want assistance please start your own thread.
PlsFixMyWIFI
Message 6 of 13
Thank you, I will if I need to.
Thought it's helpful for faberfaber to know other people are experiencing identical issue. I'll monitor this thread and see how this issue gets resolved.
faberfaber
Message 7 of 13
Thanks for the helpful answers. So a new router arrived (same hub 3.0). Now i have the same problem, but slightly worse (0.80mbit)....looks like the signal power is lower. Should I keep the old one or does it hardly make a difference ? I called again and they said they are working in the area. Well I'd like to work in the area too.
14027500005.437256 qam30
1Locked37.6110
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 13
Have you called in to get the Hub activated ?
Activation number on 0800 953 9500
faberfaber
Message 9 of 13
I did now, it says "it looks like it's already activated"
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 13
You should have 24 Downstream Channels and either 2 or 4 Upstream Channels.
You need to call it in.
You can contact VM to report the problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
