Priingleton
  • 23
Message 1 of 7
Speed drop
Hello,
I had 1Gig installed on the 11th December 2021 and everything was perfect until last week, for the last week my download speed never goes past 90 Mbps. if I reboot my hub4 modem and my router the speed will be perfect 600-900 Mbps but 50-10 minutes later the speed drops again, these speed tests have been recorded from speedtest.net (Web and CLI) Sam Knows (speedtest.samknows.com) and nperf (nperf.com).
I have tested the download speed via wifi and ethernet on BOTH the router and modem (in router mode) but I get the same results.
Any help will be appreciated.
My Broadband Ping - Home
Priingleton
  • 23
Message 2 of 7
Re: Speed drop
Please find below my stats from the hub4.
3.0 Downstream channels
26339000000-3.59999838.983261QAM25626
1139000000-0.29999938.983261QAM2561
2147000000-0.59999840.366287QAM2562
3155000000-0.90000240.366287QAM2563
4163000000-1.09999840.366287QAM2564
5171000000-1.40000240.366287QAM2565
6179000000-1.70000140.366287QAM2566
7187000000-2.09999840.366287QAM2567
8195000000-2.29999940.366287QAM2568
9203000000-2.40000240.946209QAM2569
10211000000-2.70000140.366287QAM25610
11219000000-3.00000040.366287QAM25611
12227000000-3.20000139.854763QAM25612
13235000000-3.40000239.397190QAM25613
14243000000-3.79999938.605377QAM25614
15251000000-3.90000238.983261QAM25615
16259000000-3.20000140.366287QAM25616
17267000000-3.09999838.983261QAM25617
18275000000-3.20000138.983261QAM25618
19283000000-3.09999840.366287QAM25619
20291000000-3.00000038.983261QAM25620
21299000000-3.40000240.366287QAM25621
22307000000-3.90000238.983261QAM25622
23315000000-4.29999938.983261QAM25623
24323000000-4.09999838.983261QAM25624
25331000000-3.59999838.983261QAM25625
27347000000-3.90000238.983261QAM25627
28355000000-4.20000138.983261QAM25628
29363000000-4.20000138.605377QAM25629
30371000000-4.50000038.983261QAM25630
31379000000-5.29999938.605377QAM25631
26Locked38.98326130
1Locked38.98326110
2Locked40.36628700
3Locked40.36628700
4Locked40.36628700
5Locked40.36628700
6Locked40.36628700
7Locked40.36628700
8Locked40.36628700
9Locked40.94620900
10Locked40.36628700
11Locked40.36628700
12Locked39.85476300
13Locked39.39719000
14Locked38.60537700
15Locked38.98326100
16Locked40.36628700
17Locked38.98326100
18Locked38.98326100
19Locked40.36628700
20Locked38.98326100
21Locked40.36628700
22Locked38.98326100
23Locked38.98326100
24Locked38.98326100
25Locked38.98326100
27Locked38.98326100
28Locked38.98326100
29Locked38.60537700
30Locked38.98326100
31Locked38.60537700
3.1 Downstream channels
159964K1880QAM2048759
159Locked40-9.1567371357
  • 6.08K
  • 511
  • 1.57K
Message 3 of 7
Re: Speed drop
Your BQM is a mess and the 3.1 DS Channel should be 4096 QAM, and the power is also too low, should be between -6 and +10 .
You will need a VM technician to sort this out.
Either phone in or wait here a day or two for a VM Mod to pick this up.
Paulina_Z
  • 4.31K
  • 159
  • 327
Message 4 of 7
Re: Speed drop
Hi @Priingleton,
Welcome back to our Community Forums! Thank you for your post, and I'm sorry to hear that you're experiencing some ongoing speed issues with your broadband at the moment! I can understand how frustrating this is.
I have been able to locate your account and I can see that your downstream power levels are not looking so great at the moment. As @Adduxi stated, you will need a technician appointment. I will send you a Private Message to discuss this further. Please keep an eye out for a purple envelope at the top right corner of your Forum page. I will be in touch soon.
Thank you.
Paulina_Z
Paulina_Z
  • 4.31K
  • 159
  • 327
Message 5 of 7
Re: Speed drop
Hi @Priingleton,
Thank you for coming back to me via private message and confirming your details. I have now booked you a technician visit for your speed issue – you can check and amend the date and time via the online account.
There will be no charge for this visit unless:
•    The technician diagnoses the faults as not being caused by our network/equipment
•    The technician discovers that the fault or problem relates to your equipment
•    The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Thank you.
Paulina_Z
Priingleton
  • 23
Message 6 of 7
Re: Speed drop
@Paulina_Z,
that's perfect, thank you, are you able to make sure the engineer knows what the issue is? as every time I have an engineer out, they don't know what's wrong and they don't fix anything.
Many thanks
Steven_L
  • 10.18K
  • 619
  • 1.06K
Message 7 of 7
Re: Speed drop
Thanks for coming back to us @Priingleton.
Full notes have been added to your account to advise the visiting engineer of your issues.
Regards,
Steven_L
