billkilv
  • 122
  • 9
Up to speed
Speed drop and intermittent packet loss
My speed has dropped from the 1gb to around 650mbps. I've done the usual re-boot of the hub, which I do once a week or so due to dropped packets creeping in.
This is on a wired connection to the hub, which also drops out periodically.=
Could somone check my line quality as something has deteriorated.
  • 1.91K
  • 122
  • 439
Super solver
Re: Speed drop and intermittent packet loss
Have you speed tested the service to the Hub : https://www.samknows.com/realspeed/
billkilv
  • 122
  • 9
Up to speed
That's interesting! Fine to the hub, low to the pc. Yet nothing has changed internally.
I'll swap some cables around
Thank you
  • 1.91K
  • 122
  • 439
Super solver
It is very handy to see if the Hub is OK as starting point.
650Mb/s is quite decent, if it has dropped recently perhaps new software or antivirus / security suites been installed recently.
It is possible to see if the computer hardware is capable of more speed by booting into Safe Mode + Networking then re-run the Realspeed test.
billkilv
  • 122
  • 9
Up to speed
Apolgies for not responding to helpful comments earlier.
Been working through the issues and it appears to be the PC network adaptor. I've reloaded all the drivers for it and while it appears more stable, is still slow.
I'll keep plugging away
Thanks for the advice given
  • 1.91K
  • 122
  • 439
Super solver
Try a speed test with the computer booted into Safe Mode + Networking
This will show what is possible for the hardware when operating in a minimal software configuration.
If there is large increase of performance it shows the computer software / antivirus suite  are at issue.
