Message 1 of 8
Speed drop Ultimate oomph
Hi Everyone,
Had noticed that the speed of our broadband was running slow, done speed tests over the past 24hrs wired and through wifi, tried modem reboot all with no luck. Speed seems to now max out at 250mbps. Upload seems ok, always a steady 37mbps.
I've included screenshots of the modem connection info.
Any help would be great,
Thank you.
  • 5.32K
  • 600
  • 1.77K
Message 2 of 8
Re: Speed drop Ultimate oomph
The figures posted so far look to be within spec.  You have only posted the first half of the downstream figures, if you could also post the second half that shows Pre and Post RS errors etc that might show something.
I have had to reject your network log image as it contained MAC addresses which is not allowed on the forum to protect your privacy.  The logs were showing some errors from the 14th that could indicate an issue but nothing more recent.  Usually best to copy and paste the network log as it will then be auto censored by the forum to remove MAC and IP addresses.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Message 3 of 8
Hi Scott,
I did try and create the post by only copying and pasting the information nation but everytime I done that it wouldn’t let the post submit and even though it said it had highlighted the errors it didn’t 😞
Message 4 of 8
1Locked40.350
2Locked40.950
3Locked40.350
4Locked40.350
5Locked40.350
6Locked40.950
7Locked40.350
8Locked40.350
9Locked40.300
10Locked40.310
11Locked40.940
12Locked40.950
13Locked40.950
14Locked40.340
15Locked40.900
16Locked40.360
17Locked40.350
18Locked40.350
19Locked40.350
20Locked40.960
21Locked40.350
22Locked40.3120
23Locked40.350
24Locked40.300
14/11/2019 09:32:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2019 09:32:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2019 09:32:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2019 09:32:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2019 09:32:33Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2019 09:35:8criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2019 09:38:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2019 09:39:6criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/11/2019 00:37:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2019 05:08:51ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2019 10:07:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2019 10:40:44ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2019 12:38:55ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2019 12:50:9ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2019 15:50:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2019 22:40:46ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2019 08:31:27ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2019 10:32:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/11/2019 22:36:34ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2019 04:38:1ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 5.32K
  • 600
  • 1.77K
Message 5 of 8
@Golddust wrote:
Hi Scott,
If you click "Post" or "Preview" again after it highlights errors it should "fix" the issue and let you continue.
EDIT - Looks like you got it working 😀
Scott
  • 5.32K
  • 600
  • 1.77K
Message 6 of 8
The rest of the downstream figures look OK and nothing untoward in the logs since the 14th.
Nothing obvious in the hub stats to explain the slowdown in your speeds.  Hopefully the VM forum team will be able to see something from their end when they get to this thread and run some checks.
Scott
Message 7 of 8
Thank you.
all is back to normal now.
  • 485
  • 45
  • 64
Fibre optic
Message 8 of 8
I'd recommend whenever this happens to first give a Hub reboot a shot and see how it goes after it. Usually that resolves most issues, although glad it seems to be working as expected again now 🙂
