Sianbithell
Just joined
Speed been poor
Hi my speed has been really low recently and I’ve checked it at different times of the day and on different days.  We pay for 350mbs but are getting no where near that I’ve done all the usual things rest hub, removed all connected devices etc still no joy
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Speed been poor
Are those tests using Wi-Fi or ethernet cable connected device ?
Christy_D
  • 1.65K
  • 231
  • 257
Re: Speed been poor
Good Evening
A quick and easy fix is to simply turn off your wifi within your phones wifi settings then reconnect to the wifi again.
This should automatically connect you to the 5ghz bandwidth. Once reconnected run the speedtest again on the app you have already used above or use www.fast.com.
Try and do this stood next to the modem for a more accurate result.
Hope this helps!
Christy
