Maverick2
  • 20
Message 11 of 25
Re: Speed and Connectivity serious Issues
I am in the process of setting Broadband Quality Monitor (BQM) up; I will answer within this morning.
Thanking you in advance
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 12 of 25
Can you post the Downstream data as well please.
Maverick2
  • 20
Message 13 of 25
1331000000838256 qam25
22670000008.538256 qam17
32750000008.338256 qam18
42830000008.338256 qam19
52910000008.138256 qam20
62990000008.138256 qam21
73070000008.138256 qam22
8315000000838256 qam23
9323000000838256 qam24
103710000007.538256 qam26
113790000007.338256 qam27
123870000007.138256 qam28
13395000000738256 qam29
14403000000738256 qam30
154110000006.938256 qam31
164190000006.538256 qam32
174270000006.538256 qam33
184350000006.438256 qam34
194430000006.338256 qam35
20451000000638256 qam36
214590000005.938256 qam37
224670000005.638256 qam38
234750000005.638256 qam39
244830000005.638256 qam40
1Locked38.960
2Locked38.960
3Locked38.950
4Locked38.950
5Locked38.950
6Locked38.9190
7Locked38.950
8Locked38.6200
9Locked38.640
10Locked38.900
11Locked38.900
12Locked38.940
13Locked38.650
14Locked38.960
15Locked38.960
16Locked38.600
17Locked38.960
18Locked38.950
19Locked38.660
20Locked38.960
21Locked38.600
22Locked38.950
23Locked38.900
24Locked38.910
Maverick2
  • 20
Message 14 of 25
Yes, sure. Please find it in the prior post
Kind regards
Maverick2
  • 20
Message 15 of 25
I am getting all red graph. My internet works decently so it has to do with the router configuration. I cannot the option to enable ping services in VM Hub3..... I will keep looking....and update the post
Maverick2
  • 20
Message 16 of 25
I have just found the option. I will post the graph shortly.
Maverick2
  • 20
Message 17 of 25
My BQM
Maverick2
  • 20
Message 18 of 25
I am sorry but apparently the ICMP/ping cannot be monitored for this specific router. By running a test in the Virgin Media site, I get the following:
Network issue
There's a network issue which maybe affecting your broadband service
What does this mean?
  • This issue is caused by interference on the cabling coming into your home.
  • This will cause intermittent speeds and performance may vary.
I am sure that all the cabling getting to my home is properly installed; I have even checked the outside cabling and everything looks alright. No issues are identified in my area......
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 19 of 25
Try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Maverick2
  • 20
Message 20 of 25
Hello again Mike,
Thanks for the resource. I have just called and there are no issues in my area..... I have double-checked all the cables even in the outdoor of the house and there is no issue at all. Everything is plugged as it should be and no signs of water.... by running the test again:
Thanks for doing your in-home checks. Please pop back 24 hours after you've done these checks and if you're still experiencing intermittent blips on your service you'll be able to book an engineer appointment online.
I hope I can book an engineer soon.
