Maverick2
  • 20
Message 1 of 25
Speed and Connectivity serious Issues
Since more than 3 weeks ago, I have experienced frequent outages on my Internet service. I have managed to forward mobile data as the cuts were frequent but short. Speed has been ok (60-75 Mbps in Ethernet) but slower than agreed (100 Mb). Today the crash is permanent. There is no Internet at home and we are 2 people working from home. Unacceptable! Issue seems to be in the router (Hub3) as there are no issues reported in my area. Of course, I have restarted and restored it around 20 times. I would need assistance as soon as practical. Router log shows plenty of warnings and critical entries
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 25
Re: Speed and Connectivity serious Issues
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 25
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Buffer6
  • 11.21K
  • 93
  • 632
Hero
Message 4 of 25
If there is no Internet at home, how would they set up a BQM?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 25
The OP stated "frequent outages on my Internet service."
then stated "Today the crash is permanent."
How long is permanent ?
In my book it means forever.
Set up a BQM using a mobile then once they can get the VM WAN IP edit the BQM to reflect that IP Address.
Maverick2
  • 20
Message 6 of 25
Hi @MikeRobbo,
Thank you veyr much for your replies.
I will carry out a few tasks I need to do and post later the required answers. It seems to be working now but I forecast it will crash during the morning..... Of course, I will keep you all posted. Yes, permanent is forever. Yesterday, I completely lost Internet (over 2 hours) before going to bed.
Kind regards, thanking you in advance
Maverick2
  • 20
Message 7 of 25
Downstream
13310000007.638256 qam25
22670000008.138256 qam17
3275000000838256 qam18
4283000000838256 qam19
5291000000838256 qam20
62990000007.938256 qam21
7307000000838256 qam22
83150000007.838256 qam23
93230000007.938256 qam24
103710000007.438256 qam26
11379000000738256 qam27
12387000000738256 qam28
133950000006.838256 qam29
144030000006.638256 qam30
154110000006.638256 qam31
164190000006.138256 qam32
174270000006.438256 qam33
184350000006.138256 qam34
19443000000638256 qam35
204510000005.838256 qam36
214590000005.638256 qam37
224670000005.438256 qam38
234750000005.538256 qam39
244830000005.538256 qam40
1Locked38.660
2Locked38.960
3Locked38.950
4Locked38.950
5Locked38.650
6Locked38.6190
7Locked38.650
8Locked38.9200
9Locked38.940
10Locked38.600
11Locked38.600
12Locked38.640
13Locked38.950
14Locked38.960
15Locked38.660
16Locked38.600
17Locked38.660
18Locked38.600
19Locked38.960
20Locked38.660
21Locked38.600
22Locked38.650
23Locked38.900
24Locked38.910
Maverick2
  • 20
Message 8 of 25
Upstream:
16030000442512064 qam9
23940002142512064 qam12
34619999642512064 qam11
45370003942512064 qam10
1ATDMA0010
3ATDMA0000
4ATDMA0000
Maverick2
  • 20
Message 9 of 25
General Configuration:
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
.iyewrkldJKDHSUBsgvca69834ncx
SFID23046
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID23045
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Maverick2
  • 20
Message 10 of 25
Of course, I have removed some bits of the MAC address:
Time
Priority
Description
04/12/2020 09:12:40
critical
No Ranging Response received - T3 time-out;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:42:0
notice
LAN login Success;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:26:26
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:25:36
Warning!
Lost MDD Timeout;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:25:32
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:25:32
Warning!
RCS Partial Service;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:25:32
critical
03/12/2020 22:25:31
Warning!
03/12/2020 22:22:40
notice
03/12/2020 22:15:31
notice
Unit has been restored to factory defaults from a software issued command;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:13:43
notice
03/12/2020 22:13:11
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:09:40
Warning!
03/12/2020 22:09:40
critical
03/12/2020 22:09:40
Warning!
03/12/2020 22:09:39
critical
03/12/2020 22:09:21
Warning!
03/12/2020 22:09:16
critical
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:09:16
critical
Ranging Request Retries exhausted;CM-MAC=e4:57;CMTS-MAC=0c:11:;CM-QOS=1.1;CM-VER=3.0;
03/12/2020 22:09:9
critical
