Ray_Morrissey
Speed Upgrade
Hi all.
How long should it take for a speed upgrade to take effect...M100 to M200?
I was told it would update overnight, this was two days ago.
Thanks.
Anonymous
Not applicable
Re: Speed Upgrade
How are you checking your speed?
You can check in the 'Configuration' tab on your HUB.
