  • 6
Message 1 of 7
Speed Throttling?
Hi there,
I'm not the most technical person in the world when it comes to networks and reuters, but im hoping someone can help.
I recently started streaming to Facebook as a hobby and everything was fine. I managed to meet the requirements (which have now been taken off of me) to become a level up creator. You basically have to have so many followers and stream for so many hours and a days a week. But for the past 2 weeks, everytime I go to stream my internet speed drops from around 113mbps to around 8mbps and the upload drops from around 8mps to less than 1mbs. I cannot fathom what is causing it. Its caused me to lose my status on Facebook streaming because I dont have the speed to even connect to facebook.
Ive uninstalled the app you use for streaming (streamlabs obs) and reinstalled it thinking it was maybe that but its not made a difference. I haven't changed any settings or done anything differently since i started streaming around 4 months ago. Can anyone please help.
These are the last 3 tests ive done, 2 before trying to stream and one during
Mon 26/10/2020 18:44   8.55 Mbps 4.30 Mbps 0.05 Mbps Virgin Media
Mon 26/10/2020 18:37  111.13 Mbps 109.45 Mbps 0.16 Mbps Virgin Media
Mon 26/10/2020 18:27  111.47 Mbps 106.36 Mbps 9.88 Mbps Virgin Media
  • 12.3K
  • 952
  • 1.58K
Message 2 of 7
Re: Speed Throttling?
Speed Throttling doesn't happen.
What is your contracted speed?
Which Hub do you have ?
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 6
Message 3 of 7
Hi there,
I am contracted for M100 package. When I am streaming I turn use an ethernet connection. I also have the Hub 3. I get 113mbs on that website.
  • 12.3K
  • 952
  • 1.58K
Message 4 of 7
What is the upload speed ?
Mike Robinson
  • 12.3K
  • 952
  • 1.58K
Message 5 of 7
Then
Can you please
Mike Robinson
Message 6 of 7
Are you streaming when you do your speed test by any chance ?
  • 6
Message 7 of 7
OK so I made the broadband monitor and the strangest thing happened. Its started to work! I was able to stream for 2 hours uninterrupted. I will keep the monitor running for a couple of days just to see if things revert back to their old ways. And ill come back then and post all the information from it and the reuter.
Thanks for the help. I will be back in a day or two with all the information.
