Bennicut
  • 8
Speed Testing before reporting
Good evening,
Could you help me look into checking my speed test. Currently have M500 connection but want to see how I can test the M500 to ensure I'm getting what I paid for.
I've done the app on my phone and currently see the results below.
What is the best way to check these speeds please?
Many Thanks
Ben 😁
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Speed Testing before reporting
The best way to test speed is to use a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Test at >> speedtest.net <<.
Bennicut
  • 8
Thanks for the quick response Mike,
I'll get the cable out and give it a check.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Looking at the speed test results that you posted you are getting quite good speeds for a Wi-i connection.
