Speed Issues - Started on Friday
Hello! Hope everyone's managing with the lockdown as well as they can.
I'm signed up to a 70 mbp/s package which has been relatively good in my area, but since Friday I've been reaching highs of 2-5 mbp/s on wireless and at best a fluctuating 8 mbp/s with anything from a 200 kbps-1.5 mbps upload speed on a wired one. Virgin's status in my area also has no currently known issues and is supposedly fine.
The lag on my PS4 using wired is absolutely insane, so I fear there's something wrong with how stable the connection is as well as the speed of the broadband we are getting.
Here is also the Downstream:
  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)202750000210750000N/AN/A234750000242750000250750000258750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedUnlockedUnlockedLockedLockedLockedLocked
Channel ID910N/AN/A13141516
Modulation256QAM256QAMUnknownUnknown256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.952000N/AN/A6.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
N/AN/AI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)1.041.86N/AN/A1.470.40-0.021.10
RxMER (dB)30.9532.58N/AN/A31.9231.0728.5731.20
Pre RS Errors4325022229041892N/AN/A29360623371844154386924618058388
Post RS Errors695495602334N/AN/A12829142988116278130297
Upstream:
US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID1342
Frequency (Hz)46200000326000002580000039400000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)47.7543.2544.0044.50
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
Network log:
First TimeLast TimePriorityError NumberDescription
23/06/2020 14:41:44 GMT23/06/2020 14:41:44 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:41:27 GMT23/06/2020 14:41:27 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:40:58 GMT23/06/2020 14:40:58 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:40:42 GMT23/06/2020 14:40:42 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:40:32 GMT23/06/2020 14:40:32 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:40:08 GMT23/06/2020 14:40:08 GMTWarning (5)66050310Auth Success - Web login successful.
23/06/2020 14:39:52 GMT23/06/2020 14:39:52 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:39:13 GMT23/06/2020 14:39:13 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:38:49 GMT23/06/2020 14:38:49 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:38:41 GMT23/06/2020 14:38:41 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:38:12 GMT23/06/2020 14:38:12 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:38:03 GMT23/06/2020 14:38:03 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:37:55 GMT23/06/2020 14:37:55 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:37:47 GMT23/06/2020 14:37:47 GMTWarning (5)84020200Lost MDD Timeout
23/06/2020 14:37:46 GMT23/06/2020 14:37:46 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync
23/06/2020 14:37:30 GMT23/06/2020 14:37:30 GMTWarning (5)84020200Lost MDD Timeout
Any help regarding this issue would be great, cheers!
  • 20.96K
  • 1.14K
  • 2.7K
Re: Speed Issues - Started on Friday
A couple of your downstream levels aren’t locked.
You’ll need an engineer potentially.
But first of all turn the hub off, make sure the coax cable is tight at both ends (unscrew, reseat and screw back if you wish) then boot the hub again and post the stats back here following this reboot.
